Recompile Video To Lengthen It, recompile video to lengthen it
jameslee
Posted: Sep 1 2008, 06:14 AM
laugh.gif hello everyone,nice to meet you all.
i'm trying to make a video to play slower permanently,its something like initially the video is 2mintues,i want to find a way some how make it permanently play at 2:30 minutes duration,its like a little bit slow motion version from the original one.
i tried to play around with virtualdub but i couldn't make it,can anyone give me advice on how to do it?
thanks guys
GrofLuigi
Posted: Sep 1 2008, 02:22 PM
Hi jameslee and welcome to the forum!
There are several ways to achieve what you want with Virtual Dub. First I would try with menu Video - Frame Rate (Ctrl-R) and then enter a value in the "Change frame rate to (fps):". In your case, it should be 1/5 lower then the frame rate of the original file (which can be seen in File - File Information menu item).
Then you can use "Convert to fps" item (I'm not sure which of these two would give you the desired result, since it's a long time since I used them).
More advanced ways would be with external filters (but I'm not sure if any exist - you need to download one) and using AviSynth.
When you're satisfied with the result and want to save your work, don't forget to choose appropriate video compression codec!
GL
1 replies since Sep 1 2008, 06:14 AM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
