| Trond |
| Posted: Aug 29 2008, 03:18 PM |
I downloaded the plugin, but I get error when I try to open the file type in latest VirtualDub.
Codec: FLV4/VP
Name: Flash/On2 VP6 |
| foxidrive |
| Posted: Aug 29 2008, 04:58 PM |
What does the error message say? |
| Trond |
| Posted: Aug 29 2008, 06:03 PM |
I didn't bother with the file.
Last time I tried with a different FLV file I got this
http://forums.virtualdub.org/index.php?act...=ST&f=2&t=16079 |
| Placio74 |
| Posted: Aug 29 2008, 06:40 PM |
VideoAudio
If it's still issue with FM Screen Capture Codec, disable this codec used VCSwap.
If not, show new crash report.
BTW Any sample file?
| Trond |
| Posted: Aug 30 2008, 05:46 AM |
Unable to locate a video codec to decompress the video track
I used Replay Media Catcher this time to fetch the FLV from web stream |
| Placio74 |
| Posted: Aug 30 2008, 10:30 AM |
VideoAudio
| QUOTE (Trond @ Aug 30 2008, 07:46 AM) | Unable to locate a video codec to decompress the video track | Check ffdshow VfW configuration...
| Trond |
| Posted: Aug 30 2008, 01:16 PM |
Hum... How do I start ffdshow? There isn't any exe |
| Placio74 |
| Posted: Aug 30 2008, 01:30 PM |
VideoAudio
ffdshow it's DirectShow filter (audio/video decoder) and VfW wrapper (video decoder/encoder).
If not have installed ffdshow, then download and install it. http://sourceforge.net/projects/ffdshow-tryout/
If have installed ffdshow, go to menu Start and search ffdshow configuration shortcuts.
In ffdshow VfW configuration (decoder tab) set support for VP6F and FLV1.
| Trond |
| Posted: Aug 30 2008, 01:51 PM |
I have ffdshow installed, but I didn't install icons. |
| Placio74 |
| Posted: Aug 30 2008, 02:38 PM |
VideoAudio
Menu Start > Run > C:\WINDOWS\system32\rundll32.exe ff_vfw.dll,configureVFW
Of course if VFW interface installed (selected when install) and when ff_vfw.dll is in \windows\system32\ folder...
| Trond |
| Posted: Aug 30 2008, 03:12 PM |
I downloaded the file and put it in system32 dir.
When I try to run your command nothing happens. |
| Placio74 |
| Posted: Aug 30 2008, 04:43 PM |
VideoAudio
| QUOTE (Trond @ Aug 30 2008, 05:12 PM) | I downloaded the file and put it in system32 dir. ... | ffdshow is installed?
| Trond |
| Posted: Aug 30 2008, 06:56 PM |
Add or Remove Programs in Windows XP it says:
ffdshow [rev 1723] [2007-12-24] |
| Placio74 |
| Posted: Aug 30 2008, 07:19 PM |
VideoAudio
Reinstall ffdshow.
See ffdshow video codec in VirtualDub (Video > Compression...) or not?
You installed some codec packs before? If yes, then maybe it installed ffdshow to other location and with unusual configuration...
