Deflicker Filter, anyone know ideal settings to use??
kissvid
  Posted: Aug 30 2002, 03:29 PM
Hello,
I am a new user to virtual dub and am starting to get used to this powerful tool. I need help..I downloaded a deflicker filter and it helps a little but I can't seem to find an ideal setting before processing it....I convert 8mm film footage to video and am trying to eliminate some flicker. Also Can anyone reccoemd a good filter for clearing up a video. I have some that appear slightly blured and I wanted to see if i can make them just a little bit clearer and sharper. Thank you everyone.
Marc
SillKotscha
Posted: Aug 31 2002, 10:31 PM
smart Moderator
do a search for 'Wavelet Noise Reduction'... this may helps you
cheers Sill
Sarreq Teryx
Posted: Sep 1 2002, 04:47 PM
VirtualdubMod Alpha tester
QUOTE (SillKotscha @ Aug 31 2002, 04:31 PM)
where might an actual filter be found, all I can find are the whitepapers/theses on it's application.
2 replies since Aug 30 2002, 03:29 PM Track this topic | Email this topic | Print this topic
<< Back to General Discussion
