| jazzzy786 |
| Posted: Nov 25 2004, 07:55 PM |
I am using a program called ACP which uses Avisynth, Virtualdub, Tmpgenc, Besweet ,Maplay and BBMpeg to convert an AVI to KVCD. All I have to do is choose the AVI and it does all the work for me including audio extraction (using vdub), conversion of audio to MP2 (using madplay and besweet) and Tmpgenc to convert the film to MPEG and BBMpeg to mux the video with the audio. It uses some sort of prediction to set the correct bitrate to give me a 700Mb MPG from a 700MB Avi. Great program. Only prob is I d/l quite a lot of foreign films and want to modify the script this program uses to do the following
Check if a SRT subtitle with same name exists in folder else goto nosub_routine read the SRT Subrip subtitle use SRT2SSA to convert the subtitle to SSA Load the film into virtualdub Load the subtitler filter Load SSA subtitle Frameserve to Tmpgenc
nosub_routine:
I still want to use the prediction to get the small file size as well
Can anybody out there help?
| jazzzy786 |
| Posted: Dec 21 2004, 08:09 PM |
I figured out how to write a script to keep my aspect ratio for my films
NTSC
DirectShowSource("E:FILMSFILM.MPG") BicubicResize( 352, 240, 1/3, 1/3)
PAL
DirectShowSource("E:FILMSFILM.MPG") BicubicResize( 352, 288, 1/3, 1/3)
Still can't figure out how to do subs using Avisynth |
| NuPogodi |
| Posted: Dec 22 2004, 08:34 AM |
| QUOTE (jazzzy786 @ Dec 21 2004, 02:09 PM) | | Still can't figure out how to do subs using Avisynth | I've understood that you want to encode hard subs and to load them from AviSynth? is it the problem? no problem at all... there is TextSub by Gabest... the latest ffdshow build 12.10.2004 also provides support for AviSynth and VDub - it means you can use the ffdshow's built-in subtitler. Finally, i've tested both methods and both worked properly. So, you have a choice...
-------------------- Optimists believe that they live in the best of existing worlds. Pessimists are afraid of that's right... |
| jazzzy786 |
| Posted: Dec 30 2004, 01:57 PM |
I'm still quite new to scripting any chance of an example script to load a SRT into vdub. I've got textsub (thanks), i was trying to use subtitler |
