Open File Using Avisynth "directshowsource", AVI import error : (unknown) 80040154
hubo-goss
Posted: Jun 13 2004, 04:41 PM
Hello!
I don't know if it's a hard problem but I can't find the answer on the web and in this forum....
Well, first I explain.
I got two PC.
Both of them is using win XP and virtualdubmod 1.5.10.1 all inclusive.
I installed the handlers.
I installed many codecs. ( DivX, XviD, Panasonic DV, VP6...Lame mp3)
and some filters ( FFDShow, MMswitch..)
I used to encode my DV movies using the option " use avisynth template" DIRECTSHOWSOURCE.
So I can control the post processering ( deinterlacing, brightness, sharpen...) using FFDshow configuration. It's very usefull because before encoding I can watch what do every options.
More over the last FFDShow filter include an avisynth module (It should interest many of you!?)
On the first PC it works perfectly, no problem
But on the second one (witch is faster) when I open a file using the option " use avisynth template" DIRECTSHOWSOURCE, I got the error "AVI import error : (unknown) 80040154"
What could I do in order to correct this error???
Thx a lot
0 replies since Jun 13 2004, 04:41 PM Track this topic | Email this topic | Print this topic
