Deinterlace Script
cricket
Posted: May 31 2004, 01:53 AM
Hi Guy and gals,
I have this And1 Mix Tape ( Basket Ball) dvd which is in Pal, Interlaced, aspect ratio 4:3. Can someone plz suggest a good deinterlace avisynth script? Also am trying to in crease the brightness and contrast and white balace. How I can do these function in Avisynth instead of in Vdub?
Cheers
rfmmars
Posted: May 31 2004, 06:52 AM
Deinterlacing is like fried chicken, there's a lot of ways to do it and they all taste pertty good. Down below is one that I downloaded.
I am a NTSC guy so for me and the work I do this is my simple method for getting good deinterlacing.
SepararteFields
Doubleweave
Next in VD I use Alparysoft deinterlacer as the second filter, the first filter must be "AutoLevels" or it won't work. "AutoLevels" by EOD is the best filter to do video resoration that I have found, don't let the word auto fool you, there are nine presets to play with. Most important is the choice of codec for the saved file. The only two that give me the best results are Leadtools' Mjpeg and Divx 5.01
LoadPlugin("F:\Media\AviSynth\plugins\avisynth_c.dll")
#LoadPlugin("F:\Media\AviSynth\Plugins\decomb510.dll")
LoadPlugin("F:\Media\AviSynth\Plugins\KernelDeInt140.dll")
LoadPlugin("F:\Media\AviSynth\Plugins\PeachSmoother.dll")
AVISource("I:\AVI WAV filtered\DI-Test-MC.avi")
FieldDeinterlace(full=false,threshold=5,dthreshold=17,map=false,blend=false,show=false)
#treshold 10: no frames skipped for DI; 20: small movements not recognized
#dthreshold: 15:ok; 20:small IL artef.
# TEST ON FIELD-ORDER (TFF = Order 1; BFF = Order 0)
# AssumeTFF().SeparateFields()
# AssumeBFF.SeparateFields()
Good luck
richard
photorecall.net
i4004
Posted: Jun 1 2004, 08:54 AM
you don't wanna deinterlaced sports and especially the ones where camera moves!
if humany possible,encode and watch as interlaced!
if not you should try doubleframerate(dgbob or smoothdeinterlace)
deinterlacing this will introduce nasty motion jerks and 25hz flicker....
fi you must deint. try graft's kerneldeinterlace
my signature:
cricket
Posted: Jun 1 2004, 09:52 PM
thanks guys..will see how it goes..at present I am comparing different deinterlace methods..already encoded with kerneldeint and fielddeinterlace..still couple more to go..
choice
smokeslikeapoet
Posted: Jun 16 2004, 05:28 AM
Be sure and view my latest test on denoising filters, my favorite deinterlacing script is included.
http://virtualdub.everwicked.com/index.php...=ST&f=16&t=7132
cricket
Posted: Jun 17 2004, 01:58 AM
I have looked into you script..hardly there is any special script you using to deinterlace.
smokeslikeapoet
Posted: Jun 18 2004, 10:04 AM
Nope, nothing special. It's simple and that's why I like it so much. Are you having particular problems with simple scripts? Just wondering why you would need something more complicated.
cricket
Posted: Jun 21 2004, 01:06 AM
you are right..I am just currently trying different deinterlace filters with different parameters..just trying to arrive on something which satisfying my need..thanks for trying to help me though..
7 replies since May 31 2004, 01:53 AM Track this topic | Email this topic | Print this topic
