| Jakobud |
| Posted: May 28 2004, 01:40 AM |
I made a very simple script:
VirtualDub.Open("C:\\tmp\\myfile.avi",0,0); VirtualDub.video.SetDepth(24,24); VirtualDub.video.SetMode(3); VirtualDub.video.SetFrameRate(0,1); VirtualDub.video.SetIVTC(0,0,-1,0); VirtualDub.video.SetCompression(0x78766964,0,10000,0); VirtualDub.video.SetCompData(368,"OAEAAAAAAAAAAAAAgIQeAAAAgEABAAAAAAAAAAAAAAAAAAAAAQAAADIAAAAALTEBAAAwAAAAJAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACamZmZmZnJP5qZmZmZmck/AAAAAAAAAAAAAAAAgAIAAOABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA4D8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACgAAABkAAAAAAAAAAAAAAABAAAAAQAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAAAA/////wEAAAABAAAAAAAAAAEAAAADAAAAYzpcXGRpdngubG9nAGM6XFx0ZXN0LmRpdngAYzpcXG12aW5mby5iaW4AYzpcXG5ld3JjLnR4dAA="); VirtualDub.video.filters.Clear(); VirtualDub.video.filters.Add("brightness/contrast"); VirtualDub.video.filters.instance[0].Config(15,17);
If I goto File > Load Processing Settings and load up this script, it works fine. It loads up the correct "myfile.avi" and sets up my compression and the one brightness filter fine.
But if I try to use the command line options to load up with script like this:
C:\VirtualDubMod\virtualdubmod.exe /s script.vcf
I get the following errors when VirtualDubMod opens:
Can't open script file Cannot detect file type of "C:\VirtualDubMod\script.vcf"
I don't understand this. It's the exact same script that opens just fine if I do it manually from the file menu...
Anyone get this sort of error? Can anyone help me out? Thanks!
Jake |
| Posted: May 28 2004, 05:11 AM |
No space between /s and the script filename. |
| Jakobud |
| Posted: May 28 2004, 03:59 PM |
Ah great thanks! |
