Fixvhsoversharp, syntax has me confused
nagrafall
Posted: May 16 2004, 11:47 PM
I'm back for more. Pardon the ignorance, I'm somewhat new to scripting and I'm having difficulty figuring out what is being asked for in an example like this:
Usage
FixVHSOversharp(clip clip, int brightness_change, int detection_width, int offset)
FixVHSOversharpL(clip clip, int brightness_change, int detection_width, int offset)
brightness_change: The minimum brightness change to examine for the oversharp problem. (If there isn't an oversharp problem it won't try to fix anything.) I usually set this to 40.
detection_width: The width in pixels of the oversharp scanning window. I usually set this value to 12 or 14.
Offset: The position in pixels of the working pixel. I usually set this to 8 (or detection_width-4).
What is being asked for, specifically in the expression " clip clip," and why is "clip" repeated? And is the comma then integral to the script ?
Those of you familiar with this filter, what is the author referring to when referencing the "working pixel"?
Any and all comments are welcomed. Thanks much,
Matthew
0 replies since May 16 2004, 11:47 PM Track this topic | Email this topic | Print this topic
