| Ingolf |
| Posted: Feb 7 2004, 11:29 AM |
Hi
I am using the following script:
| QUOTE | AviSource("c:\myavifile.avi") ComplementParity SeparateFields |
This will extract each field from an interlaced sorce, doubling the number of frames.
But it seems to me that every odd frame is drawn from y-position 1, and every even frame is drawn from y-position 0. Whatever happens, the result is that the whole image is jumping 1 pixel up and down for every frame. How can i fix this? I kinda need to tell avisynth, to skip the 1st line on every odd frame.. how can i do this? Maybe i can fix it in another way using vdub(with filters)? |
| rfmmars |
| Posted: Feb 7 2004, 06:25 PM |
Again see the website www.100fps for the solution and plugin for VD. You came up with the same script I did when fixing a very bad camcoder field problem.
Good luck!
Richard |
| garydude |
| Posted: Mar 16 2004, 12:55 PM |
You might want to try:
SelectOdd() or SelectEven()
I've had the best luck using Odd.
Also, you may want to try it with & without compliment parity.
Bottom line it's going to take some playing with the script. I'm sure you already know that.
| i4004 |
| Posted: Mar 16 2004, 03:59 PM |
specialised filters to achieve doubleframerate(as that is what you're essentially doing) are "dgbob"(probably avs only) and "deinterlace smooth"(replicated in avs filter "smooth deinterlacer") actually i don't know if there's vdub version of dgbob(probably not,as graft moved away from vdub filters long time ago)
find "deinterlace smooth" here http://biphome.spray.se/gunnart/video/
graft's site is down at the moment of writing,so if you're avs freak,you can search for it somewhere else...(on avs you can try both "dgbob" and "smooth deinterlacer",and see which one you liked better...any of these avs implementations should be faster than vdub filter...)
