How Do I Include Sound From Mpeg2 File, I only get video
rfmmars
Posted: Feb 5 2004, 05:15 PM
With my field problem solved, I needed to streamline the process. I need to frame serve VDMOD from a MPEG2 Video capture file.
I am using plugin (mpegdecoder.dll) with Avisynth 2.53.
I tried to use (audiodub) & (wavsource), but it says it doesn't know these commands.
Even though I am not ripping a DVD vob file, do I need to use DVD2AVI or am I leaving something out of the script?
Richard
rfmmars
Posted: Feb 7 2004, 06:33 PM
Let me restate my wishes. I need to open a mpeg2 files with audio in AVISYNTH. I am using the plugin mpegdecoder, but no sound is imported.
Please just let me know what plugin and version of AVISYNTH I need to do this, Maybe this is a simple matter for you, but I can't see the forest for the trees
Richard
garydude
Posted: Mar 16 2004, 01:05 PM
I think you're close.
Try this as part of your script:
video = (C:\.mpg)\
audio = WaveSource(C:\.wav)
AudioDub(video,audio)
Hope that helps.
NuPogodi
Posted: Mar 16 2004, 01:46 PM
Hi, Richard!
Which version of ffdshow do you use? In my case (AviSynth 2.53, latest ffdshow - 12.03.2004) the command DirectShowSource("c:\ympegout.mpg") works properly... At least, VDub can open such AVS-script (MPEG2+MP2) and, according to FileInformation, the uncompressed audio is PCM WAV. When I've used stable ffdshow build (23.05.2003) which includes no audio filters, the same DirectShow-command refuses to import audiostream... only video...
PS I've just tested multiaudio VOBs... unfortunately, the above method is not suitable to process several audiostreams.
Optimists believe that they live in the best of existing worlds. Pessimists are afraid of that's right...
3 replies since Feb 5 2004, 05:15 PM Track this topic | Email this topic | Print this topic
