| highdude |
Posted: Dec 10 2002, 06:03 PM |
hi ppl, I have a avi file. im using VD and trying to compress it to divx pro 5.02 under the configuration . Everything seems to be fine till im trying to save as avi. Than i have an Error. : "cannot start video compression." "the source image format is not acceptable." "error code -2"
preview is fine. Whats going on ??? please help me |
| valja |
| Posted: Dec 10 2002, 10:13 PM |
Did you read format restrictions for DivX 5? Check your picture size - width must be multiple of 4, height must be multiple of 2. |
| dizzy23nc |
| Posted: Jan 17 2003, 01:59 AM |
I have the error code-2 problem. I had compressed a movie twice to fix some quality problems but now after 2 trys I can no longer save to avi.
I went into the divx properties to change the width and height to the correct multiples but it still won't work. Can someone please help me?
thanks in advance |
| ChristianHJW |
| Posted: Jan 17 2003, 05:53 AM |
| QUOTE (dizzy23nc @ Jan 17 2003, 03:59 AM) | | I went into the divx properties to change the width and height to the correct multiples but it still won't work. |
You cant change that in the DivX encoder setup, but only in the resizimg filter of Virtualdub ...
| endorphin |
| Posted: Apr 22 2003, 06:43 AM |
I get this error when attempting to encode using VDub in the following scenario.
Input: 720x480, square pixels, HuffYUV "convert to YUV/predict median"
Output: attempting to run 2nd pass of DivX 5.04 beta ("schizo") encoder. 1st pass ran correctly AFAIK, no problems. attempt to begin 2nd pass (in Nth-pass mode) immediately brings this error.
Any suggestions?
=== edit ===
Forgive me, I figured it out. What happened: I was used to having my DivX 5.03 set up with the proper paths to H:\divx.log and H:\mvinfo.bin files. Notice that my hard drive is H: in this case, not the default C:.
So when I installed the DivX 5.04 beta update, it reset the default locations to C:\divx.log and C:\mvinfo.bin. Then my 1st pass ran correctly or appeared to. It should have complained that it was unable to save the log and mvinfo files... but it could not, because I had the "do not give warnings and errors" box checked! Therefore I remained unaware of the cause when my 2nd Pass failed.
If Phaeron sees this, may I suggest that the error popup for (error -2) be updated to include a note that advises the user to check whether pathways to logfiles (if any) are set correctly in the codec's configuration dialog. ?
Thanks again.
My pixel dimensions do conform to the requirements for DivX. Does DivX have a problem encoding from YUV or something? I believe I have encoded from YUV to DivX before, using 5.0.3. Could this be a 5.04 beta problem?
