In vDub 1.5.10 I have no problems.
i have a bt878, usually capture PAL-N (25fps) in a non-directly supported resolution 384x288 which is half of full PAL resolution 768x576. I wish this resolutions along with 768x288 would be added in choosable resolutions so as I could directly use them.
In 1.6.4 when I enter capture I have no monitoring sound until I start first capture, afterwards I have sound even if capture stops.
I have no overlay display until I set capture pin and preview pin to 640x288, is strange to notice that if I set both pins to 352x288 there is an almost black overlay display (carefully looking, there is a very dark image going on). So I leave 640*288 (or 720x288) pin settings and use my favourite 384x288 Custom format. Saving settings, if I exit and reenter, have same black image until I reenter pin values.
using Conexant DirectShow, I always have 5 initial drop frames (if Wait OK is enabled only 3-4 initial drop frames) No drops for Ms WDM capture (VFW)
My hardware: WinXP almost no services/programs, 2.66GHz Prescott intel 865G chipset. |
