| jumbo |
| Posted: Oct 15 2004, 10:03 AM |
Hello
Sorry for my bad english
Also: I have VirtualDub 1.5.1 and this System: Windows 2000 SP4 and all Updates Motherboard: Asus K8V SE Deluxe CPU: AMD 3400+ 64 Bit 2 X 200 GB S-ATA Harddisk 2 X 512 MB DDR RAM 400 The temperatur is ok.
When i encode movies in XVID (all days 4 or 5 series). I make all in the joblist and on 7 o'clock on evening i begin. When VirtualDub is encode (XVID 2 pass) my PC restarted. The CPU themperatur is on 50 ° and the Motherboard 32 ° (normaly)
Is this a bug on VirtualDub 1.5.1 or in Windows or what is it? On my old System a Asus Board with a AMD Athlon 1700+ and Windows 2000 SP4 and all Updates my PC don't restart
Great
jumbo |
| Posted: Oct 15 2004, 06:02 PM |
It does sound like an overheating problem. Is the temperature 50 degrees Celsius when your CPU is idle? That seems a bit warm to me. Mine is at 31 as I type this (not encoding anything).
| i4004 |
| Posted: Oct 15 2004, 08:35 PM |
by my merits, 50°c is not hot at all. on the other hand it may be hot if 50 is really 70-80, if you know what i mean.
if it's the temp, then you can monitor it while you're encoding, and when it passes certain temp. restart may happen.
my mobo displays a wrong temp for cpu readings, so i hooked up external sensor that's touching the core of cpu.
