| Nakrul |
| Posted: Aug 22 2003, 12:10 AM |
I captured a video with virtualdub 1.5.4 and compressed it in divx5.05 while capturing. I can view it now in windows media player. If i want to open it with virtualdub an error message occours.
Couldn´t locate decompressor for format "DX50"(unknown)
VirtualDub requires a Video for Windows (VFW) compatible codex to decompress video. DirektShow codecs, such as those used by Windows Media PLayer, are not suitable.
what can i do? |
| Kippesoep |
| Posted: Aug 22 2003, 09:21 AM |
Are you running Win9x? If so, check the file C:\Windows\System.ini and take a look at the [drivers32] section at the bottom. What's in there? |
| Nakrul |
| Posted: Aug 22 2003, 11:24 AM |
I running Windows 2000 Professional
and the [Driver32] Section is empty.
[driver32] [386enh] woafont=app850.FON EGA80WOA.FON=EGA80850.FON EGA40WOA.FON=EGA40850.FON CGA80WOA.FON=CGA80850.FON CGA40WOA.FON=CGA40850.FON FileSysChange=off |
| Kippesoep |
| Posted: Aug 22 2003, 11:29 AM |
For NT/2K/XP, look in the registry in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Drivers32 |
| Nakrul |
| Posted: Aug 24 2003, 07:08 PM |
anybody knows the registry entry for divx5 codec? |
| Kippesoep |
| Posted: Aug 24 2003, 07:59 PM |
In the key I specified above, you should have a value: vidc.DIVX with value DivX.dll. There shouldn't be one for vidx.DX50. |
| Nakrul |
| Posted: Aug 29 2003, 02:07 PM |
i have this key in my registry but i cant open the file... i can also select in virtualdub the divx5 codec to compress other files. But the one file i compressed in virtualdub with divx5 codec cant be reopened in virtualdub. |
| Kippesoep |
| Posted: Aug 29 2003, 03:02 PM |
Post a list of everything in that key. There might be some other codec hijacking the DX50 fourcc. (The GT Camera codec, I believe, does this). |
