How To Edit Video Frames W/o Editing Audio Frames!, This is highly annoying, please help!!!
FireHawk3029
  Posted: Jul 7 2003, 03:36 AM
Ok I JUST got this Virtual Dub so excuse my sounding ignorance, but I am simply trying to delete parts of the video frames without deleting the audio I add to it. I use Fraps to record in-game movies then I use Virtual Dub to edit them and add music, but when I edit the video the music frames are edited too so every time the movie gets to a part I edited, the music jumps too. This is highly annoying, and please help!!!!
Mr.Radar
Posted: Jul 30 2003, 11:10 PM
Extract the audio to a WAV file(be sure you have the audio set to Direct Stream Copy) then edit the file, save it(with Audio set to No Audio and any compression codec you want) then open the output and set Video to Direct Stream Copy and Audio to WAV Audio and select the wav file you saved then save it as a different file. Tada! This should work.
1 replies since Jul 7 2003, 03:36 AM Track this topic | Email this topic | Print this topic
