Read Error Writing .wav W/use Advanced Filtering, Positive audio skew error w/filtering on
epiquirm
Posted: Jun 7 2003, 12:20 AM
Thanks so much for an awesome product, and for looking at this. I really mean it.
Writing .WAV fails with "Read error on audio sample 4294962497. The source may be corrupted." message. I am experiencing this error when I try to change the audio skew correction to a _positive_ number. no problem changing it to a _negative_ number. in this case, the error can be avoided by unchecking "Use advanced filtering". I am using simple input->stereo chorus->output structure in audio filters. there is nothing wrong with the .AVI file. .AVI was captured thru firewire from DV cam. .AVI file plays fine. .WAV file is properly created if not "Use advanced filtering". Using build 16300/release and build 16297 same result.
Thanks again.
-epiquirm
Posted: Jun 7 2003, 01:36 AM
This can be reproduced in the official VirtualDub release too.
4294962497 samples is equivalent to -4799 samples, which is no doubt due to the positive skew. But I don't know much about the advanced audio filter graph and I think only phaeron can address this.
1 replies since Jun 7 2003, 12:20 AM Track this topic | Email this topic | Print this topic
