Virtual Dub 1.5.3 Crash, crash when using play in virtualdub
cd090580
  Posted: May 28 2003, 03:02 PM
Hi everyone,
My virtualdub crash when I want to select a part of a video. I set my start position and then I mode near the end of my sequence but if I click on the "play input" button virtual dub crashed. In the top left, the menu is "Dub in progress" but I can't stop it. I must use CTRL+ALT+DEL many time to close Virtual Dub.
This bug doesn't occur if I only use the slide bar to select the video part and it doesn't occur with previous versions.
PS: I use this function on a video captured from TV (music videos) and compressed with huffyuv codec in YUY2 format.
I run Virtual dub on:
Intel PII 300 Mhz
Windows 98 SE in french
128 MB Ram
10 GB + 40 GB HD
0 replies since May 28 2003, 03:02 PM Track this topic | Email this topic | Print this topic
