| cliffo |
| Posted: May 24 2003, 03:39 AM |
Not sure if this is a bug or just my system but when i try to crop video with 720xXXX pixels it doesn't display the entire frame on screen, regardless of what i set my desktop resolution to (I use Win98se). The entire horizontal res (720 pixels) is displayed but not the vertical res.
If the resolution of the frame is 768xXXX (or any other res.) the whole frame is displayed (both horizontal and vertical) and I can crop the image (top and bottom) without any problems.
Any one else have this problem??
cheers,
cliffo |
| ChristianHJW |
| Posted: May 24 2003, 05:57 AM |
Is this Virtualdub or VirtualdubMod ?
| cliffo |
| Posted: May 25 2003, 08:33 AM |
Virtualdub - all versions not any specific release... to further elaborate i can still crop a frame but its takes a lot of guess work and checking the output frame....just trying to find out why it only seems to do this with the 720 wide resolution.
cheers,
cliffo |
