Wheel Mouse, Stops?
hcker2000
Posted: May 17 2003, 09:13 AM
For some reson after I get so far in a file it wont let me use the mouse to "scroll" threw the video segment. Any one know whats up with this?
Kippesoep
Posted: May 17 2003, 02:36 PM
This is a limitation of the Windows scrollbar. There are parts of it that only handle 16bit signed integers, which have a maximum value of 32767. One of those parts is used by the mousewheel API. You can't scroll beyond that point (frame 32767)...
I doubt there's anything you can do about it.
hcker2000
Posted: May 17 2003, 10:29 PM
rar. Stupid windows. I wonder if there is any way the programer could use some thing different. Prolly isnt but still heres hopeing lol. Maby there is a patch for windows or some thing.
Kippesoep
Posted: May 19 2003, 10:20 PM
The scrollbars themselves can be set to have a greater range, but the mouse wheel API doesn't use that by default. To handle this case properly, VD would have to handle the WM_MOUSEWHEEL message itself (if you don't do Win32 programming, you'll have no idea what that means). It's not all that difficult, but I doubt it would be a very high-priority thing.
To be honest, I never knew it was even possible to use the mouse wheel for this. Can't say I think it's very useful either. You might want to try the cursor keys.
3 replies since May 17 2003, 09:13 AM Track this topic | Email this topic | Print this topic
