Sylia Error, Sylia parse error with WMV9-VCM codec
PeterPan
Posted: May 7 2003, 03:31 PM
I just want to test the WMV-VCM codec. But i get a 'Sylia parse error' if i start the jobqueue.
If i don't use the job control all works fine.
There is no problem if i use XviD or DivX 5.
The problem seems to be at the following line in the script:
VirtualDub.video.SetCompData(7760,"AwBNUwAAAABYGwA....
there is no ');' at the end!!
Is there some body who can help me?
Posted: May 8 2003, 04:49 AM
Urk...
There is a fixed line limit of 8K in the job output routine, but it appears the WM9 codec uses quite a large configuration struct -- 7K binary, about 10K BASE64 encoded. The answer is no, there is no workaround other than a code fix.
PeterPan
Posted: May 8 2003, 11:27 AM
Who corrects the code?
2 replies since May 7 2003, 03:31 PM Track this topic | Email this topic | Print this topic
