Green Line, Encoding from DV to Divx
Wayforward
Posted: May 1 2003, 06:44 PM
I generate DV files with Studio7. I use virtualdub1.5.1 to read these files and encode them to divx5.04. After encoding I have a green line at the bottom. Using Intervideo winproducer to read the DV file and generate an umcompressed file and let virtualdub encode this uncompressed file, the problem is solved. Using virtualdub to generate the uncompressed file and encode with divx, the problem stays. I have the feeling that virtualdub makes an error reading the DV file.
Does anyone has a solution to this problem?
0 replies since May 1 2003, 06:44 PM Track this topic | Email this topic | Print this topic
