| jason |
| Posted: May 1 2003, 12:18 PM |
Hi..
I thought someone would spot this in the previous version, so i didnt bother posting any details.. Looks like i was (annoyingly) wrong..
VirtualDub-1.5.1: If you load 10 things into the job control.. It will crash.. *lies* *explains properly* That is, on the 10th time you enter the compression menu.. I have to switch back and forth between the compression menu to choose xvid 1st pass and 2nd pass.
VirtualDub-1.5.2: At first i thought it was fixed, i was wrong again.. This release crashes at the 12'th time you enter the compression menu ..
These are reproducable, easily.. every single time.. Hit control+c, say "ok" .. do that 13 times and watch..
A bit annoying to say the least, as i tend to encode seasons of tvrips..
Cheers..
| Posted: May 2 2003, 02:27 AM |
1) Do you have a crash trace? 2) Are you running Windows 95/98/ME, or NT4/2K/XP? |
| jason |
| Posted: May 2 2003, 03:25 PM |
Check Below. (Note, this happens on the Non-P4 build/excecutable aswell)
Windows XP + SP1
VirtualDub crash report -- build 16189 (release-P4) --------------------------------------
Disassembly: 05f31f80: 2495 and al, 95 05f31f82: 8823 mov [ebx], ah 05f31f84: f3058b7c2428 add eax, 28247c8b 05f31f8a: 85ff test edi, edi 05f31f8c: 741e jz 05f31fac 05f31f8e: 817f0476696463 cmp dword ptr [edi+04], 63646976 05f31f95: 7415 jz 05f31fac 05f31f97: 33c0 xor eax, eax 05f31f99: 8b4c2408 mov ecx, [esp+08] 05f31f9d: 64890d00000000 mov fs:[00000000], ecx 05f31fa4: 5f pop edi 05f31fa5: 5e pop esi 05f31fa6: 83c40c add esp, 0c 05f31fa9: c21400 ret 0014 05f31fac: 85f6 test esi, esi 05f31fae: 7524 jnz 05f31fd4 05f31fb0: 687c1c0100 push 00011c7c 05f31fb5: e82a1e0000 call 05f33de4 05f31fba: 83c404 add esp, 04 05f31fbd: 89442424 mov [esp+24], eax 05f31fc1: 85c0 test eax, eax 05f31fc3: 89742410 mov [esp+10], esi 05f31fc7: 7409 jz 05f31fd2 05f31fc9: 8bc8 mov ecx, eax 05f31fcb: e850040000 call 05f32420 05f31fd0: eb02 jmp 05f31fd4 05f31fd2: 33c0 xor eax, eax 05f31fd4: 85ff test edi, edi 05f31fd6: 0f8498030000 jz 05f32374 05f31fdc: 8bc8 mov ecx, eax 05f31fde: f7d9 neg ecx 05f31fe0: 1bc9 sbb ecx, ecx 05f31fe2: 83e103 and ecx, 03 05f31fe5: 83c1fd add ecx, fd 05f31fe8: 894f14 mov [edi+14], ecx 05f31feb: 8b4c2408 mov ecx, [esp+08] 05f31fef: 64890d00000000 mov fs:[00000000], ecx 05f31ff6: 5f pop edi 05f31ff7: 5e pop esi 05f31ff8: 83c40c add esp, 0c 05f31ffb: c21400 ret 0014 05f31ffe: 85f6 test esi, esi 05f32000: 744b jz 05f3204d 05f32002: 81fe00010000 cmp esi, 00000100 05f32008: 7643 jbe 05f3204d 05f3200a: 8b862c1c0100 mov eax, [esi+11c2c] <-- FAULT 05f32010: 85c0 test eax, eax 05f32012: 7413 jz 05f32027 05f32014: 50 push eax 05f32015: e8e01c0000 call 05f33cfa 05f3201a: 83c404 add esp, 04 05f3201d: c7862c1c010000 mov dword ptr [esi+11c2c], 00000000 000000 05f32027: 8b86381c0100 mov eax, [esi+11c38] 05f3202d: 85c0 test eax, eax 05f3202f: 7413 jz 05f32044 05f32031: 50 push eax 05f32032: e8c31c0000 call 05f33cfa 05f32037: 83c404 add esp, 04 05f3203a: c786381c010000 mov dword ptr [esi+11c38], 00000000 000000 05f32044: 8b16 mov edx, [esi] 05f32046: 6a00 push 00 05f32048: 8bce mov ecx, esi 05f3204a: ff5214 call dword ptr [edx+14] 05f3204d: b801000000 mov eax, 00000001 05f32052: 8b4c2408 mov ecx, [esp+08] 05f32056: 64890d00000000 mov fs:[00000000], ecx 05f3205d: 5f pop edi 05f3205e: 5e pop esi 05f3205f: 83c40c add esp, 0c 05f32062: c21400 ret 0014 05f32065: 8b442424 mov eax, [esp+24] 05f32069: 8bce mov ecx, esi 05f3206b: 50 push eax 05f3206c: e8bf050000 call 05f32630 05f32071: b801000000 mov eax, 00000001 05f32076: 8b4c2408 mov ecx, [esp+08] 05f3207a: 64890d mov fs:[ebp], ecx 05f3207d: 0000 add [eax], al 05f3207f: 00 db 00
EAX = 00000111 EBX = 00000111 ECX = 00000004 EDX = 00000003 EBP = 0012f380 DS:ESI = 0023:00000111 ES:EDI = 0023:05f31f40 SS:ESP = 0023:0012f344 CS:EIP = 001b:05f3200a FS = 003b GS = 0000 EFLAGS = 00010206
MM0 = ee26d0008057fb16 MM1 = 7ffde0000012ff28 MM2 = ee26c9a480595d2c MM3 = 000000007ffde700 MM4 = 0012ff2800000000 MM5 = ccccccccccccd000 MM6 = 8000000000000000 MM7 = 80d8b8e7b7713d70
Crash context: An out-of-bounds memory access (access violation) occurred in module 'GLZW'...
...while querying video codec "GLZW 1.00" (compchoose.cpp:181)...
...while opening video codec with FOURCC "glzw" (compchoose.cpp:166)...
...while enumerating video codecs (compchoose.cpp:154).
Thread traces:
Thread 0000053c (Main thread) C:\p4root\dev\VirtualDub\source\Init.cpp(265) C:\p4root\dev\VirtualDub\source\Init.cpp(284) C:\p4root\dev\VirtualDub\source\Init.cpp(302) C:\p4root\dev\VirtualDub\source\Init.cpp(365) C:\p4root\dev\VirtualDub\source\Main.cpp(206) C:\p4root\dev\VirtualDub\source\Main.cpp(229)
Thread call stack:05f3200a: GLZW!DriverProc [05f30000+1f40+ca] 05f31f40: GLZW!DriverProc [05f30000+1f40+0] 76b437b0: WINMM!SendDriverMessage [76b40000+36f0+c0] 76b43707: WINMM!SendDriverMessage [76b40000+36f0+17] 76b43925: WINMM!CloseDriver [76b40000+38da+4b] 76b438ed: WINMM!CloseDriver [76b40000+38da+13] 73bd3958: MSVFW32!ICClose [73bd0000+3910+48] 004971b9: B3.EH() 77d45b5f: USER32!CallWindowProcW [77d40000+5b46+19] 77341bdf: COMCTL32!InitCommonControlsEx [77340000+16c9+516] 77341d3a: COMCTL32!DefSubclassProc [77340000+1cb0+8a] 77341d4c: COMCTL32!DefSubclassProc [77340000+1cb0+9c] 77341d54: COMCTL32!DefSubclassProc [77340000+1cb0+a4] 77365bfe: COMCTL32!EnumMRUListW [77340000+24ca3+f5b] 77341d3a: COMCTL32!DefSubclassProc [77340000+1cb0+8a] 77341d4c: COMCTL32!DefSubclassProc [77340000+1cb0+9c] 77341d54: COMCTL32!DefSubclassProc [77340000+1cb0+a4] 77d452e8: USER32!IsWindow [77d40000+52b0+38] 77d452e8: USER32!IsWindow [77d40000+52b0+38] 77341c3f: COMCTL32!InitCommonControlsEx [77340000+16c9+576] 77341c75: COMCTL32!InitCommonControlsEx [77340000+16c9+5ac] 77341cf4: COMCTL32!DefSubclassProc [77340000+1cb0+44] 77341c75: COMCTL32!InitCommonControlsEx [77340000+16c9+5ac] 77d43a68: USER32!00003a68 77d43b4b: USER32!00003b4b 77d4450d: USER32!PostMessageA [77d40000+4460+ad] 77d44518: USER32!PostMessageA [77d40000+4460+b8] 77d44518: USER32!PostMessageA [77d40000+4460+b8] 77d4b5a2: USER32!CallMsgFilterW [77d40000+b213+38f] 77d4b5b1: USER32!CallMsgFilterW [77d40000+b213+39e] 77fb4da6: ntdll!KiUserCallbackDispatcher [77f50000+64d93+13] 77d47f15: USER32!SetWindowTextA [77d40000+7eeb+2a] 77d56e22: USER32!SetDlgItemTextA [77d40000+16e03+1f] 00489523: PositionControlUpdateString() 77d44019: USER32!GetWindowLongA [77d40000+3fee+2b] 77d45cf1: USER32!DefWindowProcA [77d40000+5c55+9c] 004b9782: MenuHit() 004b9e9b: VDEnableMenuItemW32() 004ba22a: DoInitMenu() 77d45cf1: USER32!DefWindowProcA [77d40000+5c55+9c] 77d45ca8: USER32!DefWindowProcA [77d40000+5c55+53] 77d45cbc: USER32!DefWindowProcA [77d40000+5c55+67] 004babae: MainWndProc() 77d45ca8: USER32!DefWindowProcA [77d40000+5c55+53] 77d45cbc: USER32!DefWindowProcA [77d40000+5c55+67] 77f5166a: ntdll!RtlFreeHeap [77f50000+156b+ff] 77d45cbc: USER32!DefWindowProcA [77d40000+5c55+67] 004ba3e2: MainWndProc() 77f5166a: ntdll!RtlFreeHeap [77f50000+156b+ff] 77d43a68: USER32!00003a68 77d43b37: USER32!00003b37 77d4450d: USER32!PostMessageA [77d40000+4460+ad] 77d4453d: USER32!PostMessageA [77d40000+4460+dd] 77fb4da6: ntdll!KiUserCallbackDispatcher [77f50000+64d93+13] 77d54f33: USER32!GetAsyncKeyState [77d40000+14e17+11c] 77d60da4: USER32!IsDialogMessage [77d40000+20d16+8e] 004b79b0: WinMain@16() 77dd24b6: ADVAPI32!RegQueryValueExA [77dd0000+2410+a6] 70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e] 00507470: _msize() 77f52013: ntdll!RtlAcquirePebLock [77f50000+1feb+28] 77f5201c: ntdll!RtlAcquirePebLock [77f50000+1feb+31] 70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e] 77e619ef: kernel32!GetStartupInfoA [77e60000+177e+271] 70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e] 70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e] 00500de7: atexit() 00502383: WinMainCRTStartup() 70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e] 77e814c7: kernel32!GetCurrentDirectoryW [77e60000+21483+44] 70a71a29: SHLWAPI!StrCpyW [70a70000+19cb+5e]
-- End of report
| Posted: May 5 2003, 06:18 AM |
Please disable the "GLZW" codec temporarily and retest -- this codec is implicated in the crash report. |
| jason |
| Posted: May 5 2003, 06:37 AM |
The Gabest codecs were infact the source of the problem. GLZW + GPEG .. once i disabled both of those, no more crashing occurred..
Thanks! |
