Crash Error Using Virtualdub (im Desperate)
cardento
Posted: Apr 30 2003, 11:49 AM
hi all.
Usually, i havent problems encoding with virtualdub, but any days ago i started to get problems (crash in my system with other application).
Im using Divx 5.02 codec with virtualdub 1.4.13 (gmc and bidirection encoding activated)or 1.5.1, fast recompress option , 2 passes method
My system is athlon xp 1700+, 256 mb Ram and windows Me.
my system is crashing (or telling me error/abortes in job screen; i tried use no job control option, but same result). Yesterday i got a error log file.
The error log is :
VirtualDub crash report -- build 14328 (release)
Disassembly:
03cdafe0: b679 mov dh, 79
03cdafe2: 06 push es
03cdafe3: 8d6c3d02 lea ebp, [ebp+edi+02]
03cdafe7: c1fd02 sar ebp, 02
03cdafea: 2bf5 sub esi, ebp
03cdafec: 6689700a mov [eax+0a], si
03cdaff0: 0fb66a06 movzx ebp, byte ptr [edx+06]
03cdaff4: 0fb67b06 movzx edi, byte ptr [ebx+06]
03cdaff8: 0fb67106 movzx esi, byte ptr [ecx+06]
03cdaffc: 03fe add edi, esi
03cdaffe: 0fb67307 movzx esi, byte ptr [ebx+07]
03cdb002: 03fe add edi, esi
03cdb004: 0fb67107 movzx esi, byte ptr [ecx+07]
03cdb008: 8d743702 lea esi, [edi+esi+02]
03cdb00c: c1fe02 sar esi, 02
03cdb00f: 2bee sub ebp, esi
03cdb011: 6689680c mov [eax+0c], bp
03cdb015: 0fb67207 movzx esi, byte ptr [edx+07]
03cdb019: 0fb66b07 movzx ebp, byte ptr [ebx+07]
03cdb01d: 0fb67907 movzx edi, byte ptr [ecx+07]
03cdb021: 0354242c add edx, [esp+2c]
03cdb025: 0fb65b08 movzx ebx, byte ptr [ebx+08]
03cdb029: 03ef add ebp, edi
03cdb02b: 03eb add ebp, ebx
03cdb02d: 0fb65908 movzx ebx, byte ptr [ecx+08]
03cdb031: 8d5c1d02 lea ebx, [ebp+ebx+02]
03cdb035: c1fb02 sar ebx, 02
03cdb038: 2bf3 sub esi, ebx
03cdb03a: 8b5c2404 mov ebx, [esp+04]
03cdb03e: 6689700e mov [eax+0e], si
03cdb042: 83c010 add eax, 10
03cdb045: 83c301 add ebx, 01
03cdb048: 895c2404 mov [esp+04], ebx
03cdb04c: 83fb08 cmp ebx, 08
03cdb04f: 0f8cbbfeffff jl 03cdaf10
03cdb055: 8b6c2408 mov ebp, [esp+08]
03cdb059: e9ce010000 jmp 03cdb22c
03cdb05e: 896c2408 mov [esp+08], ebp
03cdb062: 33ff xor edi, edi
03cdb064: 897c2404 mov [esp+04], edi
03cdb068: 0fb62a movzx ebp, byte ptr [edx]
03cdb06b: 8bd9 mov ebx, ecx
03cdb06d: 034c2424 add ecx, [esp+24]
03cdb071: 0fb63b movzx edi, byte ptr [ebx] <-- FAULT
03cdb074: 0fb631 movzx esi, byte ptr [ecx]
03cdb077: 8d743701 lea esi, [edi+esi+01]
03cdb07b: d1fe sar esi, 1
03cdb07d: 2bee sub ebp, esi
03cdb07f: 668928 mov [eax], bp
03cdb082: 0fb67201 movzx esi, byte ptr [edx+01]
03cdb086: 0fb67b01 movzx edi, byte ptr [ebx+01]
03cdb08a: 0fb66901 movzx ebp, byte ptr [ecx+01]
03cdb08e: 8d6c2f01 lea ebp, [edi+ebp+01]
03cdb092: d1fd sar ebp, 1
03cdb094: 2bf5 sub esi, ebp
03cdb096: 66897002 mov [eax+02], si
03cdb09a: 0fb67a02 movzx edi, byte ptr [edx+02]
03cdb09e: 0fb67302 movzx esi, byte ptr [ebx+02]
03cdb0a2: 0fb66902 movzx ebp, byte ptr [ecx+02]
03cdb0a6: 8d6c2e01 lea ebp, [esi+ebp+01]
03cdb0aa: d1fd sar ebp, 1
03cdb0ac: 2bfd sub edi, ebp
03cdb0ae: 66897804 mov [eax+04], di
03cdb0b2: 0fb66a03 movzx ebp, byte ptr [edx+03]
03cdb0b6: 0fb67b03 movzx edi, byte ptr [ebx+03]
03cdb0ba: 0fb67103 movzx esi, byte ptr [ecx+03]
03cdb0be: 8d743701 lea esi, [edi+esi+01]
03cdb0c2: d1fe sar esi, 1
03cdb0c4: 2bee sub ebp, esi
03cdb0c6: 66896806 mov [eax+06], bp
03cdb0ca: 0fb66a04 movzx ebp, byte ptr [edx+04]
03cdb0ce: 0fb67b04 movzx edi, byte ptr [ebx+04]
03cdb0d2: 0fb67104 movzx esi, byte ptr [ecx+04]
03cdb0d6: 8d743701 lea esi, [edi+esi+01]
03cdb0da: d1fe sar esi, 1
03cdb0dc: 2bee sub ebp, esi
03cdb0de: 6689 db 89
Windows 4.90 (Win98 build 3000) [ ]
EAX = 07c3e0f0
EBX = 07698425
ECX = 076986e5
EDX = 078103c8
EBP = 00000049
DS:ESI = 0177:000002c0
ES:EDI = 0177:00000000
SS:ESP = 0177:07c3db34
CS:EIP = 016f:03cdb071
FS = 34ef
GS = 0000
EFLAGS = 00210202
MM0 = 1556155615561556
MM1 = 0002000200020002
MM2 = 00000000ffff0000
MM3 = 0000000000000000
MM4 = 0000000000000000
MM5 = 0000000000000000
MM6 = 0000000000000000
MM7 = 0000000000000000
Thread fffdc68f (Main thread)
T:\projects\VirtualDub_old\main\Init.cpp(219)
T:\projects\VirtualDub_old\main\Init.cpp(238)
T:\projects\VirtualDub_old\main\Init.cpp(256)
T:\projects\VirtualDub_old\main\Init.cpp(318)
T:\projects\VirtualDub_old\main\Main.cpp(182)
T:\projects\VirtualDub_old\main\Main.cpp(205)
T:\projects\VirtualDub_old\main\FilterSystem.cpp(427)
T:\projects\VirtualDub_old\main\FilterSystem.cpp(561)
Thread fffb1643 (FastWriteStream)
Thread fffb218f (Processing)
T:\projects\VirtualDub_old\main\Dub.cpp(3220)
T:\projects\VirtualDub_old\main\Dub.cpp(2835)
T:\projects\VirtualDub_old\main\Dub.cpp(2840)
T:\projects\VirtualDub_old\main\VideoSequenceCompressor.cpp(358)
T:\projects\VirtualDub_old\main\VideoSequenceCompressor.cpp(371)
T:\projects\VirtualDub_old\main\Dub.cpp(3022)
Thread fffb2fb3 (I/O processing)
03cdb071: DIVX.DLL!encore [03cb0000+172c0+13db1]
03cf3675: DIVX.DLL!encore [03cb0000+172c0+2c3b5]
03cf32b4: DIVX.DLL!encore [03cb0000+172c0+2bff4]
03d01899: DIVX.DLL!encore [03cb0000+172c0+3a5d9]
03cedbb1: DIVX.DLL!encore [03cb0000+172c0+268f1]
03cf0143: DIVX.DLL!encore [03cb0000+172c0+28e83]
03cd82e7: DIVX.DLL!encore [03cb0000+172c0+11027]
03cd1226: DIVX.DLL!encore [03cb0000+172c0+9f66]
03cca5ce: DIVX.DLL!encore [03cb0000+172c0+330e]
03d40413: DIVX.DLL!decore [03cb0000+51e30+3e5e3]
03d450b7: DIVX.DLL!decore [03cb0000+51e30+43287]
03d4524b: DIVX.DLL!decore [03cb0000+51e30+4341b]
03d44add: DIVX.DLL!decore [03cb0000+51e30+42cad]
03d44e17: DIVX.DLL!decore [03cb0000+51e30+42fe7]
03d3e9a9: DIVX.DLL!decore [03cb0000+51e30+3cb79]
03d3e863: DIVX.DLL!decore [03cb0000+51e30+3ca33]
03d3e7f6: DIVX.DLL!decore [03cb0000+51e30+3c9c6]
03d3cf74: DIVX.DLL!decore [03cb0000+51e30+3b144]
03d3c983: DIVX.DLL!decore [03cb0000+51e30+3ab53]
bff6bb26: KERNEL32.DLL!LeaveCriticalSection [bff60000+bb13+13]
03d40042: DIVX.DLL!decore [03cb0000+51e30+3e212]
03d422d1: DIVX.DLL!decore [03cb0000+51e30+404a1]
03d3b6b0: DIVX.DLL!decore [03cb0000+51e30+39880]
03d3a9fc: DIVX.DLL!decore [03cb0000+51e30+38bcc]
03cc738f: DIVX.DLL!encore [03cb0000+172c0+cf]
03cb96bd: DIVX.DLL!DriverProc [03cb0000+8420+129d]
7ff37148: OLE32.DLL!StgCreateDocfile [7ff20000+16dd0+378]
7fe8d196: OLEAUT32.DLL!SafeArrayCopyData [7fe80000+cb2f+667]
bff6b8dc: KERNEL32.DLL!IsBadHugeWritePtr [bff60000+a71f+11bd]
bff641cf: KERNEL32.DLL!ThunkConnect32 [bff60000+2e96+1339]
bff6b8f7: KERNEL32.DLL!IsBadHugeWritePtr [bff60000+a71f+11d8]
03cb867c: DIVX.DLL!DriverProc [03cb0000+8420+25c]
bff6b989: KERNEL32.DLL!IsBadHugeWritePtr [bff60000+a71f+126a]
77db199a: MSVFW32.DLL!ICSendMessage [77db0000+18fc+9e]
77db1a31: MSVFW32.DLL!ICCompress [77db0000+19cf+62]
00471da1: VideoSequenceCompressor::packFrame()
0046b3ff: Dubber::WriteVideoFrame()
bff8a127: KERNEL32.DLL!CancelWaitableTimer [bff60000+2a008+11f]
bff6b9af: KERNEL32.DLL!IsBadHugeWritePtr [bff60000+a71f+1290]
bff831c9: KERNEL32.DLL!WaitForSingleObjectEx [bff60000+2318c+3d]
bff6ca2d: KERNEL32.DLL!WaitForSingleObject [bff60000+ca1e+f]
0040bd2a: AVIPipe::getReadBuffer()
0046be13: Dubber::ProcessingThread()
0046bebf: Dubber::ProcessingThread()
0046bd86: Dubber::ProcessingThreadKickstart()
0048419c: _threadstart@4()
bff79391: KERNEL32.DLL!HeapCreate [bff60000+19063+32e]
bff76e3a: KERNEL32.DLL!VirtualQueryEx [bff60000+156c6+1774]
-- End of report
what can i do? i tried reinstall codec and programs but always the same result: i cannot encode cause always i get a error msg (about 2-4% complete). Even i riped the movie using 2 rippers, but virtualdub always crash.
Do i need install any .dll ? what can i do?
0 replies since Apr 30 2003, 11:49 AM Track this topic | Email this topic | Print this topic
