Vdub P4 1.5.0 And 1.5.1 - False Diskspace, shows in multisegment capture just 4GB
Randolph Carter
Posted: Apr 18 2003, 08:38 AM
Hi, got a strage problem when using virtualdub 1.5.0 and 1.5.1 (standard version and P4 optimized version on my new P41800 with Asus 4PB266SE:
When I start to capture (multisegment etc. enabled) VDUB shows only 4095.4 GB free space. This happens since VDUB 1.5.0 ...
Have you any idea for a workaround??
best regards from Vienna,
Posted: Apr 19 2003, 02:09 AM
This is a regression in 1.5 due to my attempts to fix disk space errors with NTFS mounted drives; it only occurs under Win9x. The disk space is measured correctly once you drop below 4GB and should not affect your capture.
1 replies since Apr 18 2003, 08:38 AM Track this topic | Email this topic | Print this topic
