| Kajol |
| Posted: Apr 9 2003, 10:14 PM |
Hi there!
Hm, the new advanced audio filters are a really great idea. But they're so instable, you have to plan every single click in forward. If you change anything or choose a filter twice, the program hangs. (Never ever click twice on "output" accidentially!) Maybe it should be disabled until it is stable. Hm, I'd really like to apply a low-pass on those high-noise videos, but since the program always hangs, I can't do it nevertheless. The older versions (up to 1.4) almost didn't hang or crash at all!
Kajol |
| Posted: Apr 10 2003, 03:05 AM |
All bug reports should contain the following:
1) The version and build which you were using, e.g. "1.5.1 official, P4 optimized." 2) What CPU you have (K6, Pentium III, P4, etc). 3) A crash dump from the application resulting from the bug, if possible.
That having been said, I cannot reproduce the bugs you describe on either the P4 or non-P4 official builds. So maybe that gives you some insight into why I released the feature. |
