Audio Encoding To Mp3 Crahses Virtual Dub, reaching video frame 9995, it's stops
atalon1
  Posted: Mar 28 2003, 07:40 AM
Hello, i'm using the lastest version of virtual dub (modifed version compatible with mpeg2). Encoding the video to divx 5.02 works when i keep the sound in wave. But when i try to compress the sound into mp3, when the encoding reach video frame 9995, the encoding stops but virtual dub is still in process. Then i have to abort it and the message is "access violation ... divx" appeared. I'm sorry i have forgotten the crashinfo file, so i will send it later.
I thought it was beccause of my audigy player mp3 codec, so i installed lame codec, but it's the same problem. I changed the video file, and it is still the same : no encoding after the 9995 video frame.
If more informations needed, please ask me.
Thanks for help.
Sorry, i've just read other posts about 9995 error but i don't have a DV card Pinnacle but a ATI 8500DV.
Sorry to be late but here is the crash-info file :
VirtualDub crash report -- build 15654 (release)
Disassembly:
0197bd00: 742c jz 0197bd2e
0197bd02: 8915206ca201 mov [01a26c20], edx
0197bd08: c745fcffffffff mov dword ptr [ebp-04], ffffffff
0197bd0f: 8bc2 mov eax, edx
0197bd11: ebc4 jmp 0197bcd7
0197bd13: 8b45dc mov eax, [ebp-24]
0197bd16: 8d4870 lea ecx, [eax+70]
0197bd19: e8e2900000 call 01984e00
0197bd1e: c3 ret
0197bd1f: 8b45dc mov eax, [ebp-24]
0197bd22: 8d8818010000 lea ecx, [eax+118]
0197bd28: e8d38bffff call 01974900
0197bd2d: c3 ret
0197bd2e: 8b82dc000000 mov eax, [edx+dc]
0197bd34: 50 push eax
0197bd35: ff1528b29f01 call dword ptr [019fb228]
0197bd3b: 8b45dc mov eax, [ebp-24]
0197bd3e: c780dc00000000 mov dword ptr [eax+dc], 00000000
000000
0197bd48: c745fcffffffff mov dword ptr [ebp-04], ffffffff
0197bd4f: eb86 jmp 0197bcd7
0197bd51: b8703fa301 mov eax, 01a33f70
0197bd56: e9726b0600 jmp 019e28cd
0197bd5b: 90 nop
0197bd5c: 90 nop
0197bd5d: 90 nop
0197bd5e: 90 nop
0197bd5f: 90 nop
0197bd60: 55 push ebp
0197bd61: 8bec mov ebp, esp
0197bd63: 6aff push ff
0197bd65: 6878be9701 push 0197be78
0197bd6a: 64a100000000 mov eax, fs:[00000000]
0197bd70: 50 push eax
0197bd71: 64892500000000 mov fs:[00000000], esp
0197bd78: 83ec1c sub esp, 1c
0197bd7b: 8965f0 mov [ebp-10], esp
0197bd7e: 897de0 mov [ebp-20], edi
0197bd81: 8975e8 mov [ebp-18], esi
0197bd84: 895de4 mov [ebp-1c], ebx
0197bd87: 894ddc mov [ebp-24], ecx
0197bd8a: c745fc00000000 mov dword ptr [ebp-04], 00000000
0197bd91: c745fc01000000 mov dword ptr [ebp-04], 00000001
0197bd98: 8b4ddc mov ecx, [ebp-24]
0197bd9b: 8a8130060000 mov al, [ecx+630] <-- FAULT
0197bda1: 84c0 test al, al
0197bda3: 7416 jz 0197bdbb
0197bda5: 33c0 xor eax, eax
0197bda7: 50 push eax
0197bda8: 50 push eax
0197bda9: 6a02 push 02
0197bdab: 51 push ecx
0197bdac: e84f8f0300 call 019b4d00
0197bdb1: 8b4ddc mov ecx, [ebp-24]
0197bdb4: c6813006000000 mov byte ptr [ecx+630], 00
0197bdbb: 8b5168 mov edx, [ecx+68]
0197bdbe: 85d2 test edx, edx
0197bdc0: 7412 jz 0197bdd4
0197bdc2: 33c0 xor eax, eax
0197bdc4: 50 push eax
0197bdc5: 50 push eax
0197bdc6: 6a01 push 01
0197bdc8: 52 push edx
0197bdc9: e8e2940000 call 019852b0
0197bdce: 83c410 add esp, 10
0197bdd1: 8b4ddc mov ecx, [ebp-24]
0197bdd4: 8b81d0000000 mov eax, [ecx+d0]
0197bdda: 85c0 test eax, eax
0197bddc: 7409 jz 0197bde7
0197bdde: 8b10 mov edx, [eax]
0197bde0: 50 push eax
0197bde1: ff5208 call dword ptr [edx+08]
0197bde4: 8b4ddc mov ecx, [ebp-24]
0197bde7: 8b81d4000000 mov eax, [ecx+d4]
0197bded: 85c0 test eax, eax
0197bdef: 7409 jz 0197bdfa
0197bdf1: 8b10 mov edx, [eax]
0197bdf3: 50 push eax
0197bdf4: ff5208 call dword ptr [edx+08]
0197bdf7: 8b4ddc mov ecx, [ebp-24]
0197bdfa: 8b81d8000000 mov eax, [ecx+d8]
EAX = 0012f004
EBX = 73b3acc0
ECX = 00f33c80
EDX = 00000004
EBP = 0012efc4
DS:ESI = 0023:00f33c80
ES:EDI = 0023:00000000
SS:ESP = 0023:0012ef9c
CS:EIP = 001b:0197bd9b
FS = 0038
GS = 0000
EFLAGS = 00010216
MM0 = 0000138c0000138c
MM1 = 0000138c0000138c
MM2 = 0000138c0000138c
MM3 = 0000138c0000138c
MM4 = 0012f72000000000
MM5 = 8000000000000000
MM6 = d000000000000000
MM7 = d000000000000000
Crash context:
An out-of-bounds memory access (access violation) occurred in module 'DivX'.
Thread traces:
Thread 0000035c (Main thread)
D:\vdub\VirtualDub\source\Init.cpp(247)
D:\vdub\VirtualDub\source\Init.cpp(268)
D:\vdub\VirtualDub\source\Init.cpp(286)
D:\vdub\VirtualDub\source\Init.cpp(348)
D:\vdub\VirtualDub\source\Main.cpp(190)
D:\vdub\VirtualDub\source\Main.cpp(213)
D:\vdub\VirtualDub\source\VideoSource.cpp(569)
D:\vdub\VirtualDub\source\VideoSource.cpp(597)
D:\vdub\VirtualDub\source\FilterSystem.cpp(424)
Thread 00000758 (FastWriteStream)
Thread 0000036c (I/O processing)
D:\vdub\VirtualDub\source\Audio.cpp(1662)
D:\vdub\VirtualDub\source\Audio.cpp(1657)
Thread call stack:Incorrect VirtualDub.vdi file (build 15653) for this version of VirtualDub -- call stack unavailable.
-- End of report
jcsston
Posted: Apr 14 2003, 05:47 AM
Matroska Dev
Do you by any chance have a Creative sound card?
Use the Matroska file format
atalon1
Posted: Apr 15 2003, 10:54 AM
Hi, of course i have a creative sound card, it's an audigy player.
My configuration :
Abit KR7A_RAID
3d prophet AIW 8500DV (last drivers)
Creative Audigy player (last cd driver)
AMD 1800+
2*256Mo DDR 333
Windows xp home + sp1
Stea1th
Posted: May 2 2003, 02:53 PM
I have the same problem. I have the creative audigy mp3 sound card and can't encode to mp3. I've given up on trying to figure out how to get it to work. No one's been able to tell me how to fix it either. I think it has to do with the fact that creative comes with its own mp3 codec. It may interfere with virtualdub
endorphin
Posted: May 3 2003, 07:31 AM
After the SoundBlaster Live! gave everyone headaches with VIA/AMD motherboards, and after watching Creative Labs' responses to the problem for a long time, I'll never buy another Creative soundcard. No problems after almost 2 years with my Turtle Beach Santa Cruz.
4 replies since Mar 28 2003, 07:40 AM Track this topic | Email this topic | Print this topic
