| TCmullet |
| Posted: Mar 6 2015, 05:09 AM |
I was using Trevlac's excellent WFM (waveform monitor) AKA Color Tools 1.5, which I had used in the somewhat distant past and had not used for some years. But when I use it now, I can get it to show the WFM in the output pane. But if I attempt to go back into the "Filters" to open this filter back up to reconfigure it, VirtualDub blows up before even getting back into the Filters area. And because this is Windows 7 (which interferes with the crash process), I can't give the normal full dump (that I know of). It merely gives this:
| CODE | Problem signature: Problem Event Name: APPCRASH Application Name: VirtualDub.exe Application Version: 1.10.4.0 Application Timestamp: 526d9abc Fault Module Name: StackHash_497b Fault Module Version: 6.1.7601.18247 Fault Module Timestamp: 521ea8e7 Exception Code: c0000374 Exception Offset: 000ce753 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 497b Additional Information 2: 497b3189df0ce5ba22e41fc51671f2cc Additional Information 3: ea8a Additional Information 4: ea8a61c1e88c06e6898e5a1c2f5feff5
Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
| shekh |
| Posted: Mar 6 2015, 08:46 AM |
Original plugin has defect If you can wait ~12hrs I will post my corrected version
http://forums.virtualdub.org/index.php?act...t=ST&f=7&t=6129 |
| shekh |
| Posted: Mar 6 2015, 09:24 AM |
In fact turns out I have it at hand, attached to last msg |
