Missing Codec - Mp4v, please help
picaso
  Posted: Jun 2 2014, 03:32 AM
Im trying to load an mp4 video, I have QuickTime.vdplugin & QuickTime64.vdplugin installed, I also have ffdshow installed,
if Im still missing this codec , can someone please post the codec here ? No packages please , just the mp4V codec.
Also I like to know what the V stands for in mp4V ?
raffriff42
Posted: Jun 2 2014, 03:51 AM
The only input plugin I need is this one: FFmpeg input driver.
...And sometimes the built in DirectShow plugin.
Anyway, mp4v is a subtype of MPEG-4 Video (divx/xvid/h263/etc).
picaso
Posted: Jun 2 2014, 04:33 AM
Ok, when I unzip - where does this folder have to go ? ffdlls ?
raffriff42
Posted: Jun 2 2014, 05:04 AM
QUOTE (picaso @ Jun 2 2014, 04:33 AM)
From the link:
QUOTE (Abrazo @ Apr 1 2014, 08:35 PM)
Installation means : unzip FFInputDriver.vdplugin into the plugins32 folder of your VirtualDub installation + unzip the *.dll files into plugins32\ffdlls
picaso
Posted: Jun 3 2014, 03:23 AM
QUOTE (raffriff42 @ Jun 2 2014, 05:04 AM)
From the link:
Yes , I have done that , but its still not working, still complains missing codec mP4v.
My plugin for .WMV works very well with virtualdub
picaso
Posted: Jun 3 2014, 09:44 AM
Ok it turns out I had to re-install a large codec pack from - http://www.codecguide.com/download_k-lite_...c_pack_full.htm
,but now Yes its loading mp4 ,but the video is on an angle, what settings do I need to change to straighten the mp4 video ?
Posted: Jun 3 2014, 08:32 PM
When the framesize of that video is not a multiple of 4/8/16 pixels, it can be that the actual decoder has a problem with it, and that the images are not shown as straigth.
May I recommend you to try to open the video from within VirtualDub by using the DirectShow or the FFMPeg inputdriver plugins (like raffriff42 already proposed to do).
You can find the DirectShow plugin here: http://forums.virtualdub.org/index.php?act...=ST&f=7&t=15093
(take care to whether install the 32- or 64-bits version corresponding to the xx-bit installation of VirtualDub).
Repeating once again:
When in the "Open video file"-dialogbox of VirtualDub:
> first select the video (one single click);
> then at "Files of type" do select "DirectShow input driver"
> and then click onto the Open-button.
You can try the similar action when using the FFMPeg inputdriver plugin (now selecting "FFMPeg Supported Files").
Good luck.
picaso
Posted: Jun 4 2014, 04:51 AM
QUOTE (Abrazo @ Jun 3 2014, 08:32 PM)
Good luck.
that will only work if ffdshow is installed , correct ??? I have the FFInputDriver.vdplugin already in my plugin folder, but at "files of type" this option does not show at open files. Is this because when I installed ffdshow , by default they are mostly turned off(disabled) like this - attached screen shot- http://www.mediafire.com/view/0lujmgore75l.../no-ffdshow.jpg
raffriff42
Posted: Jun 4 2014, 05:39 AM
FFinput does not depend on ffdshow - they are independent of one another.
Are you running VirtualDub 32 bit 1.10.x?
Have you put the files in the plugins32 folder, like this?
...and you don't see the FFMpeg option in the open dialog?
picaso
Posted: Jun 4 2014, 06:04 AM
QUOTE (raffriff42 @ Jun 4 2014, 05:39 AM)
Im not sure ?
it says - version 1.9.11 build 32842 . One thing I do remember when I installed this version, there were no plugins32 or plugins64 folders. Im running windows 8 , 64bit .
Posted: Jun 4 2014, 06:13 PM
The recent version of FFMPeg inputdriver plugin is NOT compatible with VirtuaDub 1.9.11 and does not show up in "Files of type:".
So, an extra thing to do, is to install (unzip) the most recent version of VirtualDub 1.10.5-xx (at preference 64-bit, corresponding to the operating system):
> http://forums.virtualdub.org/index.php?act...ST&f=15&t=22042
and install (also unzip) the FFMPeg plugin (64-bits) to its plugins64 subfolder.
Let us hope that you can get it finally at work ...
10 replies since Jun 2 2014, 03:32 AM Track this topic | Email this topic | Print this topic
