| Dowlphin |
Posted: Apr 9 2014, 02:32 PM |
Used VDub 1.9.11 - all fine. Did nothing but update to 1.10.4 and now when I start rendering of a video, the input picture will move quite a lot downwards in the frame, leaving a black bar at the upper edge (or empty pixels that fill with whatever covers it) and cut off picture at the lower edge. Just a display issue - rendered video is fine. Bothers me a bit though, since I can't always check whether image contents are alright. Not dependent on encoder used, but doesn't happen on a Divx5 video I opened for render. Happens on AVC videos (h264/x264). Also happens if I use ffdshow-AVISynth for opening a video.
If I resize the input preview window to 50%, the pixel width of that offset remains the same. It's always 70 pixels.
Happens during playback in VDub, too.
Not sure whether this is really a bug or a user-fixable issue. |
| Posted: Apr 9 2014, 02:45 PM |
Haven't seen anything like that You could try playing with the display options, untick 'use directx for display panes' (and all suboptions) and see if that changes it at all
| Dowlphin |
Posted: Apr 9 2014, 02:53 PM |
Thanks. Disabling DX or additionally enabling D3D fixed it. I could have thought of that myself, but I'm getting a bit confused with all the things I'm trying to fix lately. |
| Posted: Apr 9 2014, 03:04 PM |
TBH I usually just disable those options as a force of habit - some graphics drivers can do odd things with directx/3d, especially if they have 'optimized' settings for movies
