| rmanal |
| Posted: Mar 19 2014, 06:52 PM |
Hello,
i'm using deshaker on an MP4 file, and VD is crashing under the 1.10.4 but not with the 1.9.11. Here the crash error file of the 1.10.4: VirtualDub crash report -- build 35491 (release) --------------------------------------
Disassembly: 7c812f40: 013b add [ebx], edi 7c812f42: c60f84 mov byte ptr [edi], 84h 7c812f45: 8519 test [ecx], ebx 7c812f47: 0300 add eax, [eax] 7c812f49: 8975e4 mov [ebp-1ch], esi 7c812f4c: 834dfcff or dword ptr [ebp-04h], 0ffh 7c812f50: e81c000000 call 7c812f71 7c812f55: 8b45e4 mov eax, [ebp-1ch] 7c812f58: e8b4f5feff call 7c802511 7c812f5d: c20c00 ret 000c 7c812f60: ff db 0ffh 7c812f61: ff db 0ffh 7c812f62: ff db 0ffh 7c812f63: ff00 inc dword ptr [eax] 7c812f65: 0000 add [eax], al 7c812f67: 00712f add [ecx+2fh], dh 7c812f6a: 817c9090909090 cmp dword ptr [eax+edx*4-70h], 8d909090 8d 7c812f72: 45 inc ebp 7c812f73: cc int 3 7c812f74: 50 push eax 7c812f75: ff154412807c call dword ptr [7c801244] 7c812f7b: c3 ret 7c812f7c: 90 nop 7c812f7d: 90 nop 7c812f7e: 90 nop 7c812f7f: 90 nop 7c812f80: 90 nop 7c812f81: 8bff mov edi, edi 7c812f83: 55 push ebp 7c812f84: 8bec mov ebp, esp 7c812f86: 83ec50 sub esp, 50h 7c812f89: 8b4508 mov eax, [ebp+08h] 7c812f8c: 8365b800 and dword ptr [ebp-48h], 00h 7c812f90: 8945b0 mov [ebp-50h], eax 7c812f93: 8b450c mov eax, [ebp+0ch] 7c812f96: 56 push esi 7c812f97: 8b7514 mov esi, [ebp+14h] 7c812f9a: 83e001 and eax, 01h 7c812f9d: 85f6 test esi, esi 7c812f9f: 8945b4 mov [ebp-4ch], eax 7c812fa2: c745bc812f817c mov dword ptr [ebp-44h], 7c812f81 7c812fa9: 0f8499000000 jz 7c813048 7c812faf: 8b4d10 mov ecx, [ebp+10h] 7c812fb2: 83f90f cmp ecx, 0fh 7c812fb5: 0f87051a0300 ja 7c8449c0 7c812fbb: 85c9 test ecx, ecx 7c812fbd: 894dc0 mov [ebp-40h], ecx 7c812fc0: 7407 jz 7c812fc9 7c812fc2: 57 push edi 7c812fc3: 8d7dc4 lea edi, [ebp-3ch] 7c812fc6: f3a5 rep movsd 7c812fc8: 5f pop edi 7c812fc9: 8d45b0 lea eax, [ebp-50h] 7c812fcc: 50 push eax 7c812fcd: ff151015807c call dword ptr [7c801510] 7c812fd3: 5e pop esi <-- FAULT 7c812fd4: c9 leave 7c812fd5: c21000 ret 0010 7c812fd8: 85ff test edi, edi 7c812fda: 0f8e5e8effff jle 7c80be3e 7c812fe0: 8b55fc mov edx, [ebp-04h] 7c812fe3: 89550c mov [ebp+0ch], edx 7c812fe6: 0fb716 movzx edx, word ptr [esi] 7c812fe9: 8b7df8 mov edi, [ebp-08h] 7c812fec: 8a143a mov dl, [edx+edi] 7c812fef: 8811 mov [ecx], dl 7c812ff1: 8b780c mov edi, [eax+0ch] 7c812ff4: 0fb6d2 movzx edx, dl 7c812ff7: 668b1457 mov dx, [edi+edx*2] 7c812ffb: 663b16 cmp edx, [esi] 7c812ffe: 0f8599870300 jnz 7c84b79d 7c813004: 8b5008 mov edx, [eax+08h] 7c813007: 668b5a04 mov bx, [edx+04h] 7c81300b: 3819 cmp [ecx], bl 7c81300d: 0f8497870300 jz 7c84b7aa 7c813013: 46 inc esi 7c813014: 46 inc esi 7c813015: 41 inc ecx 7c813016: ff4d0c dec dword ptr [ebp+0ch] 7c813019: 75cb jnz 7c812fe6 7c81301b: e91e8effff jmp 7c80be3e 7c813020: 8b4d10 mov ecx, [ebp+10h] 7c813023: e84c73ffff call 7c80a374 7c813028: 8b550c mov edx, [ebp+0ch] 7c81302b: 8bd8 mov ebx, eax 7c81302d: 43 inc ebx 7c81302e: e9399effff jmp 7c80ce6c 7c813033: 8bd9 mov ebx, ecx 7c813035: 895d08 mov [ebp+08h], ebx 7c813038: e92e9dffff jmp 7c80cd6b 7c81303d: 8b35 mov esi, [ebp] 7c81303f: 9c pushfd
Built on Althena on Sun Oct 27 15:59:07 2013 using compiler version 1400
Windows 5.1 (Windows XP x86 build 2600) [Service Pack 3] Memory status: virtual free 152M/2048M, commit limit 5213M, physical total 3327M
EAX = 096bf5b4 EBX = 73d76b76 ECX = 00000000 EDX = 00000003 EBP = 096bf604 ESI = 096bf644 EDI = 096bf644 ESP = 096bf5b0 EIP = 7c812fd3 EFLAGS = 00000206 FPUCW = ffff027f FPUTW = ffffffff
Crash reason: Unhandled Microsoft C++ Exception
Crash context: An exception occurred in module 'kernel32'...
...while compressing frame 22 from 0dc80020 to 0d080020 using codec "DivX 6.9.2 Codec (2 Logical CPUs)" (w32videocodecpack.cpp:787)...
...while running thread "Processing" (thread.cpp:197).
Pointer dumps:
EAX 096bf5b0: 77be14bc e06d7363 00000001 00000000 7c812fd3 00000003 19930520 096bf654 EBX 73d76b72: c3000460 ffa194e8 c3c033ff 0377f6e8 28408b00 247c80c3 0a745c04 04247c80 ESI 096bf640: 73dd47b4 096bf658 73d70d28 096bf654 73dd47b4 73df23d0 00bf3ff7 73d76b7b EDI 096bf640: 73dd47b4 096bf658 73d70d28 096bf654 73dd47b4 73df23d0 00bf3ff7 73d76b7b ESP 096bf5b0: 77be14bc e06d7363 00000001 00000000 7c812fd3 00000003 19930520 096bf654 096bf5d0: 73dd47b4 7c9201db 7c809a7f 00150000 00140008 7c809a90 00000000 06171fac 096bf5f0: ffffffff 7c91e920 7c9201e0 ffffffff 7c9201db 096bf644 77bf272c e06d7363 096bf610: 00000001 00000003 096bf638 77bfc407 00000000 e06d7363 00000001 00000000 EBP 096bf600: 7c9201db 096bf644 77bf272c e06d7363 00000001 00000003 096bf638 77bfc407 096bf620: 00000000 e06d7363 00000001 00000000 00000000 00000003 19930520 096bf654 096bf640: 73dd47b4 096bf658 73d70d28 096bf654 73dd47b4 73df23d0 00bf3ff7 73d76b7b 096bf660: 73d23e14 00bf3ff7 00000000 0254c454 096bf6dc 096bf90c 06050784 00bf3ff7
Thread call stack: 7c812fd3: kernel32!RaiseException [7c800000+12f81+52] 7c812fd3: kernel32!RaiseException [7c800000+12f81+52] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 7c809a7f: kernel32!LocalAlloc [7c800000+9a2d+52] 7c809a90: kernel32!LocalAlloc [7c800000+9a2d+63] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 77bf272c: msvcrt!_CxxThrowException [77be0000+126f6+36] 73d70d28: MFC42!00050d28 73d76b7b: MFC42!00056b7b 73d23e14: MFC42!00003e14 06050784: DivX!DriverProc [05fd0000+7484+79300] 0604df60: DivX!DriverProc [05fd0000+7484+76adc] 0604e079: DivX!DriverProc [05fd0000+7484+76bf5] 77bfc3ce: msvcrt!free [77be0000+1c21b+1b3] 77bfc3e7: msvcrt!free [77be0000+1c21b+1cc] 0602df9d: DivX!DriverProc [05fd0000+7484+56b19] 77bfc3ce: msvcrt!free [77be0000+1c21b+1b3] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 06032a27: DivX!DriverProc [05fd0000+7484+5b5a3] 06044060: DivX!DriverProc [05fd0000+7484+6cbdc] 06049f23: DivX!DriverProc [05fd0000+7484+72a9f] 7c921028: ntdll!wcsncpy [7c910000+1057f+aa9] 7c921086: ntdll!wcsncpy [7c910000+1057f+b07] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 7c9201db: ntdll!RtlAllocateHeap [7c910000+100c4+117] 77bfc3c9: msvcrt!free [77be0000+1c21b+1ae] 77bfc3ce: msvcrt!free [77be0000+1c21b+1b3] 77bfc3ce: msvcrt!free [77be0000+1c21b+1b3] 77bfc3e7: msvcrt!free [77be0000+1c21b+1cc] 77bfc42e: msvcrt!malloc [77be0000+1c407+27] 06066fa8: DivX!DriverProc [05fd0000+7484+8fb24] 7c9225c3: ntdll!_strcmpi [7c910000+12314+2af] 7c9200b8: ntdll!RtlFreeHeap [7c910000+ff2d+18b] 060366be: DivX!DriverProc [05fd0000+7484+5f23a] 0606714a: DivX!DriverProc [05fd0000+7484+8fcc6] 01f04d7e: Deshaker!VirtualdubFilterModuleDeinit [01ee0000+29c0+223be] 06036456: DivX!DriverProc [05fd0000+7484+5efd2] 05fd3c28: DivX!00003c28 005eec00: VDFontRendererD3D9::Init() 05fd79dd: DivX!DriverProc [05fd0000+7484+559] 005eec00: VDFontRendererD3D9::Init() 75ba1938: MSVFW32!ICSendMessage [75ba0000+190d+2b] 75ba4db0: MSVFW32!ICCompress [75ba0000+4d4d+63] 005da2ee: VDVideoCompressorVCM::PackFrameInternal() 005dad85: VDVideoCompressorVCM::CompressFrame() 7c802600: kernel32!WaitForSingleObjectEx [7c800000+2550+b0] 7c802600: kernel32!WaitForSingleObjectEx [7c800000+2550+b0] 7c802542: kernel32!WaitForSingleObject [7c800000+2530+12] 0048c99b: VDThreadedVideoCompressor::ProcessFrame() 7c80262a: kernel32!WaitForSingleObjectEx [7c800000+2550+da] 0048ceed: VDThreadedVideoCompressor::ExchangeBuffer() 00424353: VDDubVideoProcessor::WriteFinishedVideoFrame() 00424dec: VDDubVideoProcessor::ProcessVideoFrame() 0044317d: FilterInstance::RunRequests() 004250ca: VDDubVideoProcessor::RunPathWriteOutputFrames() 00425cdf: VDDubVideoProcessor::WriteVideo() 00422d3e: VDDubProcessThread::ThreadRun() 004f9917: ?$VDProtectedAutoScope1::?$VDProtectedAutoScope1() 0051a2dc: VDThread::StaticThreadStart() 005fcc0e: _callthreadstartex() 005fccb3: _threadstartex@4() 7c80b729: kernel32!GetModuleFileNameA [7c800000+b56f+1ba]
-- End of report |
| Posted: Mar 19 2014, 07:31 PM |
Looks like its crashing in DivX encoder Did you use exactly the same source file and settings with both versions of virtualdub? Does it happen if you use a different encoder? Are you using the latest deshaker?
| rmanal |
| Posted: Mar 20 2014, 06:35 PM |
I'm doing exactly the same for both VD.
I'm using the normal DIVX encoder, and deshaker 3.0.
It does not crash with cinepak.
More info: */ when I select cinepak and "run video analysis pass", no problem, but if I select DIVX, it says "video compression error: the source image format is not acceptable (error code -2). But it does the same for both VD version, so I don't know if there is a link.
*/ Argh, in fact I have not done exactly the same thing in both cases: With the 1.9 I have used directshow filter to import the file, and with the 1.10 the FFEM. So with the 1.10 if I use the diectshow it works. So the issue seems to come from the FFEM. |
| Posted: Mar 20 2014, 07:00 PM |
FFEM - is that the FFMPeg plugin? Latest version of that is 0.8.1.0, some crashes were fixed lately
[edit] It's 0.8.1.1 now I've fixed a problem with getting the last few frames of the source video
| rmanal |
| Posted: Mar 24 2014, 07:19 AM |
OK I will test with the last one. |
| rmanal |
| Posted: Mar 28 2014, 11:34 AM |
I have tested with the last version of FFMPeg plugin: - If I don't use vshaker, it works - If I use vshaker I have the same crash
Here the VD folder with the plugin I use and the MP4 file I use.
Rmanal |
| rmanal |
| Posted: Mar 29 2014, 10:03 AM |
Oups. The link: http://9giga.sfr.fr/n/50-17/share/LNK11865...653369a3c19ff9/ |
| Posted: Mar 29 2014, 10:51 AM |
Worked fine here
Started a clean virtual pc Installed divx Extracted your rar file (and tested with it + it's included plugins) Set divx to 1080hd profile Opened video with ffmpeg plugin Added deshaker, set pass 1 Run video analysis pass Set deshaker to pass 2 Saved avi OK
Your saved crashlog still shows it was divx crashing while trying to compress a frame
| rmanal |
| Posted: Mar 30 2014, 10:01 AM |
In my config I cannot run the video analysis; I got the error message: "Video compression error: the source image format is not acceptable (error code -2)": what does it mean?
Could you show me your deshaker config and which version of DIVX you have used?
It is very strange, but hopefully not blocking me. |
| Posted: Mar 30 2014, 12:51 PM |
That error means your giving divx an fps, width or height that is not compatible with the profile you have selected That's why I selected the 1080 profile in the list above
I used your own files, so you already have the deshaker config I said I downloaded divx, so it was the one from about 2 days ago
In general, codecs need widths and heights that are multiples of 2,4,8 or 16 Feeding them bad sizes will usually cause an error If codecs have a profile selection, you must make sure the video fits that profile
| rmanal |
| Posted: Mar 31 2014, 06:32 AM |
So it could be due to the fact that when you apply the pass 1 of deshaker, the size is a little bit larger in the output of VD, probably causing the issue with DIVX (as I have also the last version).
Do you see the same? |
| rmanal |
| Posted: Apr 18 2014, 09:47 AM |
I have tested on 3 differents PC and: - I don't see the crash in the DIVX. So probably an issue on my own PC - When I run the "Run video analysis pass" with DIVX selected in compression, I get always the message "video compression error: the source image format is not acceptable (error code -2)", which seems to be normal as deshaker, during the first pass, modify the size in a way not acceptable for DIVX codec. But not problem if I select another codec.
Thank you for your support, Rmanal |
