Bug In "append Avi Segment", bug in "append avi segment"
gdvalle
Posted: Jul 9 2013, 05:38 PM
I am using Virtualdub 1.10.4 prerelease.
I was working 6 avi files that constituted a single movie, total duration 1 hour 34 mins.
I joined the 6 avi's through the function "append avi segment", then I launched
a general re-encode (I had to resize the video and change the audio).
Well, I obtained a movie with a duration of more than 3 hours !!
The first part was what I wanted, but after the regular movie Virtualdub attached
additional copies of my clips in a confused order.
Please, have a look at "append avi segment": I fear it appends too much !!
Regards
Posted: Jul 9 2013, 07:10 PM
Opening a file as well as append have an auto-append option, was that ticked?
Auto appending will add the files in strict numeric order
Over three hours sounds like they were appended multiple times
gdvalle
Posted: Jul 10 2013, 06:46 AM
OK, Dloneranger, you are right.
The option "automatically load linked segments" was on, so when I opened the first file VDub loaded the full movie.
I made a mistake when I loaded the second, third, .... They were already in.
Thanks and regards
2 replies since Jul 9 2013, 05:38 PM Track this topic | Email this topic | Print this topic
