Save Wav Adds Junk Metadata In File
isidro
Posted: Nov 19 2012, 10:47 PM
When I binary compare extracted WAVs from AVIs, I find out that there's a small block (titled JUNK followed by some 0x00) right after the header, I get some warnings in other programs (ie FLAC) about this metadata being lost. Could it be posible to generate WAVs without this metadata?
Or else whats the use for it?
Thanks!
Posted: Nov 20 2012, 06:15 AM
It's normal behaviour for virtualdub
JUNK sections are just that, a small section of 'you can ignore this bit' that can be discarded
You can just let any other program discard it
There are 2 sizes of wav headers - the normal wav header and a larger one for files over 2GB
What happens is that the largest size is saved at the beginning, then the wav data is saved
Then if the file is >2GB the WAV64 header is filled in
If the file is <2GB, the normal wav header is filled in
But because the normal header is smaller, there are a few bytes of nothing in between the header and the data, so that's filled in with the JUNK section
Posted: Nov 24 2012, 08:47 PM
That's pretty strange... no program should be warning about a "JUNK" chunk being lost. It's specifically for padding out parts of the file and doesn't have any attached meaning.
2 replies since Nov 19 2012, 10:47 PM Track this topic | Email this topic | Print this topic
