| jobotslash |
| Posted: Oct 3 2012, 10:07 PM |
I opened up the Capture AVI... from the File menu in VirtualDub, then tried to use the MultiCam from the Device menu. The window opened up properly, and when I went to select the video size, I accidentally clicked the Full HD setting (1920x1080), and it made the window HUGE, and I am unable to select any of the options to change it back, making this mode unusable.
I've attempted using the auxsetup.exe and removing all custom properties for VirtualDub, attempted the registry cleanup and removed/reinstalled the DLLs via this panel. The issue persists and the size of this window is unchanged (I made all of these alterations after closing the program and reopened to test them).
So, anyone have any ideas as to how to fix that? I searched all over the forum and googled for solutions but found none. |
| John I. |
| Posted: Oct 4 2012, 02:14 PM |
@ jobotslash
I'm not quite sure, but I think it was mentioned somewhere here in the forum that if you click on capture while pressing SHIFT, it will bypass the settings.
You can search the forum for "shift and capture" without the quotes.
