Fcchandler In Codec Search?
Dstruct
Posted: Feb 28 2012, 04:17 PM
Anybody knows what the "Use video stream fccHandler in codec search" option does (Preferences/AVI)? I'm using all fccHandler plugins. Do I need to enable it?
ale5000
Posted: Feb 28 2012, 04:40 PM
Do not confuse the fccHandler thing with the "fccHandler" nickname.
New VirtualDub forum
Dstruct
Posted: Feb 29 2012, 08:05 AM
Not the same? Do you know what this option does?
Placio74
  Posted: Feb 29 2012, 10:21 AM
VideoAudio
phaeron's answer from... "use Video Stream Fcchandler In Codec Search" topic:
QUOTE (phaeron @ Mar 6 2011, 12:02 AM)
This setting only matters if you have the codecs that were originally used to encode the video. The reason I added this option was that previously the codec fourcc was included in the search, which meant that the codec that was used on your system sometimes depended on what was used to encode it, and two videos that used the same compression sometimes opened with different codecs for no apparent reason. The default is now to ignore the codec fourcc so that, for instance, all XVID encoded files open with the same codec.
Dstruct
Posted: Mar 1 2012, 04:06 PM
Thanks!
4 replies since Feb 28 2012, 04:17 PM Track this topic | Email this topic | Print this topic
