Selection Start Incorrect In Direct Stream Copy, Selection Start Incorrect
tuaris
  Posted: Oct 27 2011, 12:56 AM
Running the latest version of virtual dub 1.9.11.
I am attempting to manually cut some large videos (captured from video tape) into multiple individual parts and save them as separate files titled according to it's content. Both video and audio are in DIRECT STREAM COPY mode.
The problem I run into is that when I specify the selection start and end, the output video does not start where I selected it. It's always about 6.5 seconds more than I want at the start. I've confirmed this on multiple computers and with multiple videos.
Placio74
Posted: Oct 27 2011, 04:39 AM
VideoAudio
Start selection is on a keyframe?
What video format (DV, MJPEG, ...)?
mayhem
Posted: Oct 28 2011, 06:39 AM
I've seen this too, I believe its normal behaviour for direct stream.
It will go back to the previous keyframe (maybe forward if nearer? not sure),
but I've definately seen it go back multiple times and that can be anywhere
from a fraction of a second to several seconds depending on how far apart your
keyframes are in whatever format video it is.
In most .avi type videos its usually not an issue due to fairly
tight keyframes at least as far as I've noticed. In other formats
it may be a large enough issue to warrant full process mode, however.
tuaris
Posted: Oct 30 2011, 03:32 AM
Okay, I understand now why it happens. I guess the correct way is to always use full processing mode. But won't that create a lower quality copy?
ale5000
Posted: Oct 30 2011, 11:59 AM
Use the "Smart rendering".
New VirtualDub forum
4 replies since Oct 27 2011, 12:56 AM Track this topic | Email this topic | Print this topic
