Help: Vdub Freezes With .mts Files, Always freezing at approx. 94-98%
plamen
Posted: Aug 26 2011, 05:12 AM
Hi to all,
I don't know why and how it started, but after replacing with the newest VD version and adding the newest Deshaker 3.0 I experience something that never happened ever before:
When I load .MTS file on VD timeline (via DShow Input Driver, of course), then nothing can help it to be processed. Even when only playback the .mts video files on the VD timeline (i.e. without any processing), the program freezes at ~94% or just before the end of every .mts clip. Absolutely shocking!!! The .mts files are from my Panasonic Lumix DMC-G2 that I always use on VD especially for stabilize processing with Deshaker without any problems, error, bugs, etc. Until now!
I tried with few previous versions of VD again, even with Deshaker 2.5, 2.7, but the freezing doesn't go away.
Please for any suggestion and help!!!
Big thanks in advance!
Jim_pansen
Posted: Sep 2 2011, 01:34 AM
You should better use ffmpeg input driver plugin! It works awesome good!
http://forums.virtualdub.org/index.php?act...=ST&f=7&t=20025
Jim
freedomdwarf
Posted: Sep 2 2011, 02:32 PM
Sounds like a bad block in the original input file - AVI files also have a habit of doing that if the copy has a hiccup somewhere.
Sometimes, something as simple as a CHKDSK and/or Defrag can cure that if it was caused by bad HD architecture/structure.
2 replies since Aug 26 2011, 05:12 AM Track this topic | Email this topic | Print this topic
