In VirtualdubMod, the current selected range was saved to the VCF file. (well, reading did not fully work)... but in the current Vdub (1.9.11) the range is not saved. If I add the line VirtualDub.video.SetRange(int startMS, int endMS) to the VCF file, the range is read.
So could you please fix saving the range?
Oops... It's ms offset, not frames? got changed since 1.5, eh? Well, does not matter if no manual interaction is required, ie. it's saved to the VCF file.
thanks. |
