Screen Capture Not Working
HackworthVDUB
Posted: Jul 18 2011, 08:51 AM
the screen capture function does not work for me.
The preview and actual output of the capture area is a solid black, with the exception of the mouse cursor, which is recorded properly.
Other devices, such as my webcam, work as they should. Only Screen capture is affected.
I am running Win 7 Enterprise x64 sp1. The error occurs equally with vdub 1.9.11 and 1.10, both x86 and x64.
I used a fresh download, I did not change any of the default settings except the capture device of course. Playing around with the capture area or format settings did not improve anything either.
freedomdwarf
Posted: Jul 18 2011, 02:14 PM
As far as I know, all Windows flavours are able to do a simple screen capture - you don't need VirtualDub to do it.
Simple keyboard combinations -
Ctrl+PrintScrn captures the whole screen, including the task bar.
Alt+PrintScrn captures the current window in focus.
The mouse pointer is not included in the capture.
The image is saved in your clipboard to paste into any graphics package.
HackworthVDUB
Posted: Jul 19 2011, 01:46 PM
Obviously, I am talking about a video recording of the screen, this being the VDub forum and all.
Posted: Jul 19 2011, 03:32 PM
Hmmm, if i remember right, after going into capture mode, go to the video menu ->source
Untick use opengl
HackworthVDUB
Posted: Jul 19 2011, 03:50 PM
QUOTE (dloneranger @ Jul 19 2011, 03:32 PM)
Untick use opengl
Thank you very much, that did it.
4 replies since Jul 18 2011, 08:51 AM Track this topic | Email this topic | Print this topic
