Crash - Vdmod_resize With Newer Virtualdub Builds
-vdub-
Posted: Apr 30 2011, 12:46 PM
Post here since affects more than one version. v1.9.10.b33842 and v1.10.0.b33848
With older v1.9.8.b32706 it works fine.
Crashing happens after changing a setting or not with vdmod_resize.vdf filter. And select view change or accept change and exit virtualdub filter manager with vdmod_resize.vdf in the filter manager for processing.
Has something changed in newer version so that i need to adjust some setting in virtualdub to use VDMod_Resize.vdf ?
Here is the the crash reports and video (clip) along with vdmod_resize.vdf used.
http://www.sendspace.com/file/nkpfwg
Posted: May 1 2011, 01:03 AM
Turn off Direct3D mode in Options > Preferences > Display and see if that fixes it. It looks like there may be some fixes in the display code that I haven't integrated into the dev line yet.
-vdub-
Posted: May 1 2011, 03:31 AM
Phaeron thanks to your suggestion it's working again as previously did with no crashes smile.gif
2 replies since Apr 30 2011, 12:46 PM Track this topic | Email this topic | Print this topic
