| ale5000 |
| Posted: Apr 9 2011, 05:10 PM |
I'm not sure if the bug is in VirtualDub or in the input plugin (or both).
Test file: http://www.multiupload.com/ARMQ853HHL
I have opened the file with the Matroska input plugin 2.8, set crop to 2x2, set compression to Xvid, audio to direct stream copy. The encoding don't pass the first frame, look at the image:
Log: | CODE | [*] Beginning dub operation.
[i] Dub: Input (decompression) format is: XRGB8888.
[i] Dub: Output (compression) format is: XRGB8888.
[i] Dub: I/O thread has not cycled for thirty seconds -- possible livelock. (Thread action: stalled due to full pipe to processing thread) (Current address: 7C91E514)
[i] Dub: Processing thread has not cycled for thirty seconds -- possible livelock. (Thread action: running main loop) (Current address: 005D90F5)
[i] Dub: Processing thread has not cycled for thirty seconds -- possible livelock. (Thread action: running main loop) (Current address: 0042819B)
[i] Dub: Processing thread has not cycled for thirty seconds -- possible livelock. (Thread action: running main loop) (Current address: 005D8C69) |
Status dump: | CODE | ================= Processing thread =================
Completed: No Error encountered: No Video push ended: No Video ended: No Flushing compressor: No Codec frames buffered: 1
The processing thread is busy and could not be suspended. |
When I abort it say: | CODE | VirtualDub Internal Error Something appears to be struck while trying to stop (thread deadlock). Abort operation and exit program? |
| Posted: Apr 9 2011, 09:42 PM |
In my case it just crashes immediately, and it's not hard to reproduce. It also crashes with the test RGB color cube video.
I think it has everything to do with Xvid and the frame size, because it works fine if I choose no compression, OR if I increase the frame size to 16 x 16 with Xvid.
