| cht |
| Posted: Nov 15 2010, 03:44 AM |
Hi guys
I'm trying to edit an .avi file, but when I try to import the video, I'm getting this error:
"VirtualDub Error
Couldn't locate decompressor for format 'xvid' (unknown)
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable."
What I've done: - I've installed the Xvid and K-Lite package codecs. - Can't find any resolutions from Google search. I tried doing what was said on this website - http://www.moviecodec.com/video-codecs/help-couldnt-locate-decompressor-for-format-xvid-virtualdub-requires-a-vfw-codec-26374/ . I downloaded the codec from http://www.free-codecs.com/Nic_XviD_Codec_download.htm , but that didn't solve the problem.
Most avi files work, but there a few files which get this error. I've tried on two PC's, one running Windows 7 32bit and Windows XP 32bit.
Any suggestions?
Thanks in advance |
| mayhem |
| Posted: Nov 15 2010, 05:07 AM |
Eventually this is something that needs to be fixed, probably in the encoders themselves, unless some kind of special routine can be written in VirtualDub for it.
But at any rate, depending on the software used to create the file there may have been a uppercase/lowercase issue or other fourcc issue.
Try clicking the "ask for extended options after this dialog" checkbox in the Open dialog then select your file and click open, in the pop-up window that appears check off both
"Force video format FourCC code to" "Force video handler FourCC code to"
and enter XVID in capital letters into those boxes before clicking OK.
If that doesn't work, and it usually does, but if not maybe the codec wasn't installed properly or is in conflict with another codec trying to shanghai the xvid fourcc.
| mayhem |
| Posted: Nov 15 2010, 05:17 AM |
And actually, if the above doesn't work another option is trying to open the file via the DirectShow input filter, hunt down the input filter add-on in this forum, here:
http://forums.virtualdub.org/index.php?act...=7&t=15093&st=0
Install it into virtualdub, if memory serves you just unzip it into plugins32 sub-folder, that is to say make sure the .vdplugin file in the archive ends up in plugins32.
The restart VirtualDub, go to Open File, select your file but do NOT click Open yet, instead use the drop-down "File Types" box to select "Directshow Input driver", then click Open and it'll try to run the file thru directshow filter rather than xvid codec.
This often works for other types of screwy files too.
One of the above methods, either the extended options, with XVID capitalized in force fourcc, or this option with directshow filtering should work, if not then the file is probably seriously damaged in some way.
| Placio74 |
| Posted: Nov 15 2010, 06:46 AM |
VideoAudio
Or... install Jawor's Xvid build (that supports lowercase FourCC).
| cht |
| Posted: Nov 16 2010, 12:46 AM |
| QUOTE (Placio74 @ Nov 15 2010, 06:46 AM) | | Or... install Jawor's Xvid build (that supports lowercase FourCC). | Sweet that solved the problem.
Thanks !!! |
| vduser78 |
| Posted: Dec 23 2011, 05:24 AM |
| QUOTE (mayhem @ Nov 15 2010, 05:07 AM) | Eventually this is something that needs to be fixed, probably in the encoders themselves, unless some kind of special routine can be written in VirtualDub for it.
If that doesn't work, and it usually does, but if not maybe the codec wasn't installed properly or is in conflict with another codec trying to shanghai the xvid fourcc. |
| QUOTE | Try clicking the "ask for extended options after this dialog" checkbox in the Open dialog then select your file and click open, in the pop-up window that appears check off both
and enter XVID in capital letters into those boxes before clicking OK. |
IT WORKED, thanks! |
