Capture Not Saving File Anymore
BlueRobin
Posted: Feb 13 2003, 02:38 PM
Had my first crack at virtualdub v1.4.13 last night. Worked out how to do it, then added sound. All fine and saving files okay. But, then virtualdub crashed. Quick reboot of system and back in. Then noticed that although virtualdub seems to be processing a capture, the result is that no file is saved to the disk. wacko.gif Not sure if the crash is related though?
I'm using virtualdub 1.4.13 on Windows XP with AMD XP+ 2000, 768MB RAM and a cheapo Hauppage WinTV Go card.
I deleted the app files and removed the virtualdub regsitry keys, but same behaviour still exists.
Cheers
Neil
0 replies since Feb 13 2003, 02:38 PM Track this topic | Email this topic | Print this topic
