Hello all,
I noticed a strange behavior in Capture Mode. When you want to set or unset the capture audio in capture/Settings (F9), whatever you do, the "Capture audio" check box is always unchecked. For instance, if you check it, press OK and go back to settings, it is still uncheck... Is that an identified bug? Is this option disable sound capture? I have no sound card so I wonder if that option disables the sound capture. I couldn't capture video so far because Virtualdub displays "Couldn't get audio format"...
BTW, I use virtualdub 1.4.13 version
Any suggestion?
Thanks.
Sébastien |
