| Phil_123 |
| Posted: Sep 2 2010, 03:18 PM |
Sample video and crashinfo.txt is archived inside this .7z: http://www.sendspace.com/file/cstcpo
I was trying to reencode it with x264, CRF20. VirtualDub crashes at frame 327 of the sample video. Deleting the bad frame then undoing the delete also crashes VirtualDub. Direct stream copy works fine though.
Tested with VirtualDub 1.9.9 and 1.9.10-test3 on Windows 7 Ultimate x64. |
| Posted: Sep 2 2010, 03:54 PM |
It's a corrupt video (the file, not the download...)
You can open it with directshow plugin and it doesn't crash on frames 327 & 328, but those frames are garbage
And for anyone not wanting to download 100Mb for the crash report
| CODE | VirtualDub crash report -- build 32817 (release) --------------------------------------
Disassembly: 021e5b60: 22c8 and cl, al 021e5b62: 02e9 add ch, cl 021e5b64: 8acd mov cl, ch 021e5b66: 2acc sub cl, ah 021e5b68: d6 salc 021e5b69: 22c8 and cl, al 021e5b6b: 2ae9 sub ch, cl 021e5b6d: 002e add [esi], ch 021e5b6f: 8a66fd mov ah, [esi-03h] 021e5b72: 8a6c3301 mov ch, [ebx+esi+01h] 021e5b76: 8a7433fd mov dh, [ebx+esi-03h] 021e5b7a: f6de neg dh 021e5b7c: 8acd mov cl, ch 021e5b7e: 02f5 add dh, ch 021e5b80: 02f4 add dh, ah 021e5b82: 2acc sub cl, ah 021e5b84: d6 salc 021e5b85: 22c8 and cl, al 021e5b87: 2ae9 sub ch, cl 021e5b89: 02e1 add ah, cl 021e5b8b: 8ace mov cl, dh 021e5b8d: 2acd sub cl, ch 021e5b8f: d6 salc 021e5b90: 83c602 add esi, 02h 021e5b93: 22c8 and cl, al 021e5b95: 02e9 add ch, cl 021e5b97: 8acd mov cl, ch 021e5b99: 2acc sub cl, ah 021e5b9b: d6 salc 021e5b9c: 22c8 and cl, al 021e5b9e: 2ae9 sub ch, cl 021e5ba0: 006eff add [esi-01h], ch 021e5ba3: 3bf7 cmp esi, edi 021e5ba5: 7299 jc 021e5b40 021e5ba7: 5b pop ebx 021e5ba8: 5f pop edi 021e5ba9: 5e pop esi 021e5baa: 5d pop ebp 021e5bab: c3 ret 021e5bac: 55 push ebp 021e5bad: 57 push edi 021e5bae: 56 push esi 021e5baf: 53 push ebx 021e5bb0: 8b742414 mov esi, [esp+14h] 021e5bb4: 8b7c2418 mov edi, [esp+18h] 021e5bb8: 8b6c241c mov ebp, [esp+1ch] 021e5bbc: 8b06 mov eax, [esi] 021e5bbe: 8907 mov [edi], eax 021e5bc0: 83c704 add edi, 04h 021e5bc3: b820000000 mov eax, 00000020 021e5bc8: 8da42400000000 lea esp, [esp+00] 021e5bcf: 8da42400000000 lea esp, [esp+00] 021e5bd6: 8da42400000000 lea esp, [esp+00] 021e5bdd: 8d4900 lea ecx, [ecx+00h] 021e5be0: 8bd8 mov ebx, eax 021e5be2: 8ac8 mov cl, al 021e5be4: c1eb05 shr ebx, 05h 021e5be7: 8b149e mov edx, [esi+ebx*4] 021e5bea: 8b5c9e04 mov ebx, [esi+ebx*4+04h] <-- FAULT 021e5bee: 0fa5da shld edx, ebx, cl 021e5bf1: 83ca01 or edx, 01h 021e5bf4: 0fbdda bsr ebx, edx 021e5bf7: 0fb3da btr edx, ebx 021e5bfa: 8b1c9d30861e02 mov ebx, [ebx*4+021e8630] 021e5c01: 8a0b mov cl, [ebx] 021e5c03: d3ea shr edx, cl 021e5c05: 0fb64c1a01 movzx ecx, byte ptr [edx+ebx+01h] 021e5c0a: 0fb69998ae1e02 movzx ebx, byte ptr [ecx+21eae98] 021e5c11: 03c3 add eax, ebx 021e5c13: 880f mov [edi], cl 021e5c15: 8bd8 mov ebx, eax 021e5c17: 8ac8 mov cl, al 021e5c19: c1eb05 shr ebx, 05h 021e5c1c: 8b149e mov edx, [esi+ebx*4] 021e5c1f: 8b5c9e04 mov ebx, [esi+ebx*4+04h] 021e5c23: 0fa5da shld edx, ebx, cl 021e5c26: 83ca01 or edx, 01h 021e5c29: 0fbdda bsr ebx, edx 021e5c2c: 0fb3da btr edx, ebx 021e5c2f: 8b1c9d70a01e02 mov ebx, [ebx*4+021ea070] 021e5c36: 8a0b mov cl, [ebx] 021e5c38: d3ea shr edx, cl 021e5c3a: 0fb64c1a01 movzx ecx, byte ptr [edx+ebx+01h] 021e5c3f: 0fb69998b81e02 movzx ebx, byte ptr [ecx+21eb898] 021e5c46: 03c3 add eax, ebx 021e5c48: 884f01 mov [edi+01h], cl 021e5c4b: 8bd8 mov ebx, eax 021e5c4d: 8ac8 mov cl, al 021e5c4f: c1eb05 shr ebx, 05h 021e5c52: 8b149e mov edx, [esi+ebx*4] 021e5c55: 8b5c9e04 mov ebx, [esi+ebx*4+04h] 021e5c59: 0fa5da shld edx, ebx, cl 021e5c5c: 83ca01 or edx, 01h 021e5c5f: 0f db 0fh
Built on Aegis on Fri Apr 09 14:35:40 2010 using compiler version 1400
Windows 6.1 (Windows Vista x64 build 7600) []
EAX = 0029ffe8 EBX = 00014fff ECX = 000000e8 EDX = 00000000 EBP = 03c3a820 ESI = 0e050000 EDI = 03b988c8 ESP = 0d5cfc0c EIP = 021e5bea EFLAGS = 00010216 FPUCW = 027f FPUTW = ffff
Crash context: An out-of-bounds memory access (access violation) occurred in module 'huffyuv'...
...reading address 0E0A4000...
...while decompressing video frame 327 (VideoSource.cpp:2141)...
...while using input buffer at 0e050000-0e09eb87 (VideoSource.cpp:2140)...
...while using output buffer at 02d40080-02ed5083 (VideoSource.cpp:2139)...
...while running thread "Processing" (thread.cpp:163).
Pointer dumps:
EBX 00014ffb: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 ESI 0e050000: 80138013 66a9e104 16416416 863ca6b9 3cbd8c9e 69b67ad3 5afd2f4e 54ff5bdb EDI 03b988c8: 5e719470 5e749475 5e719471 5e6f946f 5d739474 5e729372 5e739371 5f7e937f ESP 0d5cfc08: 0071ef98 00000b40 03b70020 02d40080 03c3a820 021e480f 0e050000 03b70020 0d5cfc28: 03c3a820 0d5cfc8c 73b0c7c0 0d5cfc74 006e1868 00000003 00000002 0278fe50 0d5cfc48: 021e115d 0d5cfc8c 00000018 73af1759 0278fe50 00000001 0000400d 0d5cfc8c 0d5cfc68: 00000018 0071ea60 0071eea8 0d5cfca4 73af4e27 73b0c7c0 0000400d 0d5cfc8c EBP 03c3a820: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 03c3a840: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 03c3a860: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 03c3a880: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Thread call stack: 021e5bea: huffyuv!DriverProc [021e0000+1000+4bea] 021e480f: huffyuv!DriverProc [021e0000+1000+380f] 021e115d: huffyuv!DriverProc [021e0000+1000+15d] 73af1759: MSVFW32!ICSendMessage [73af0000+1728+31] 73af4e27: MSVFW32!ICDecompress [73af0000+4dea+3d] 0059cee1: VDVideoDecompressorVCM::DecompressFrame() 004dd363: VideoSourceAVI::streamGetFrame() 00477d16: ?$VDRenderBufferAllocator::FreeFrame() 004212e9: VDDubVideoProcessor::DecodeVideoFrame() 00422656: VDDubVideoProcessor::ReadVideoFrame() 00424efc: VDStreamInterleaver::PushStreams() 00424f04: VDStreamInterleaver::PushStreams() 7418271c: WINMM!timeGetTime [74180000+26f0+2c] 0042318e: VDDubVideoProcessor::WriteVideo() 00425353: VDStreamInterleaver::GetNextAction() 00420759: VDDubProcessThread::ThreadRun() 004dc567: ?$VDProtectedAutoScope1::?$VDProtectedAutoScope1() 00519186: VDThread::StaticThreadStart() 005b7e6e: _callthreadstartex() 005b7f13: _threadstartex@4() 76743677: kernel32!BaseThreadInitThunk [76730000+13665+12] 77229d42: ntdll!RtlInitializeExceptionChain [771f0000+39cdf+63] 77229d15: ntdll!RtlInitializeExceptionChain [771f0000+39cdf+36]
-- End of report
| levicki |
| Posted: Oct 31 2010, 02:30 PM |
So, how is this fault of VirtualDub when it crashed in external huffyuv codec? |
| Posted: Nov 3 2010, 09:51 PM |
Go to Options > Preferences > AVI and check the "prefer internal video decoders" checkbox. This will force VirtualDub's internal Huffyuv decoder, which should be a bit more robust to decoding errors (it's written with preference to robustness over decoding speed). |
