File/avi Info Popup (vbr) Audio Length Error
AEN007
Posted: Jan 27 2009, 12:16 PM
27Jan2009
Greetings.
I have noticed the VirtualDub
File/AVI Info Popup sometimes gives
an incorrect measure of the Audio Length -
seemingly when the audio is vbr audio ...
in case that is of interest to anyone ...
VirtualDubMod 1.5.10.2.2542 does not
have this problem ...
Thank you.
Regards,
AEN
Æ
Placio74
Posted: Jan 27 2009, 12:26 PM
VideoAudio
You can disable this message.
Options > Preferences... > AVI > Warn when VBR audio is detected
Don't worry - current version of VirtualDub support VBR audio.
Posted: Jan 28 2009, 05:45 AM
Confirmed -- I'll fix this for 1.9.1.
AEN007
Posted: Jan 16 2012, 08:32 AM
QUOTE (AEN007 @ Jan 24 2011, 06:48 PM)
QUOTE (Placio74 @ Jan 10 2011, 10:13 AM)
Use MediaInfo and compare video files properties.
Dirk Paehl has a freeware collection of portable utilities -
including an MediaInfo alternative, which I have found gives some spec info the MI normally does give but does not always seem to give on YT flv downloads (e.g., video bitrate)
I have flv YT download and am not sure what the dimensions are.
MI & DPMI say 480x360.
The ViDub File Info popup says 480x368.
I have JetAudio set to give file explorer info tip popups for some MM files.
JA says 480x368.
When I play the flv in SMPlayer, the SMP File properties popup says 480x360.
When I play the flv in VLC, the VLC Media Info popup says 480x360.
I am wondering what is going on ...
ale5000
Posted: Jan 16 2012, 12:59 PM
Post the file so I can check.
New VirtualDub forum
AEN007
Posted: Jan 16 2012, 02:53 PM
16January2012
This link is to an 18.5mb YT flv file with 480x? dimensions ...
AEN007
Posted: Jan 21 2012, 03:01 PM
21January2012
Any news?
This link has a chart of flv/avc codec IDs.
The chart lists codec IDs 2, 3, 4, 5 & 6.
MI & DPMI say the YT flv file(s) in question have codec ID: 7
Anyone know some/any/thing about codec ID: 7?
Placio74
Posted: Jan 23 2012, 07:52 AM
VideoAudio
QUOTE (AEN007 @ Jan 16 2012, 10:32 AM)
This should be 480x360.
However, info from file information window is technically correct - in sense that opened video has a 480x368 (is a bit stretched?).
After changing container (to Matroska or MP4) issue does not occur.
Issue occurs only if video is in FLV container and has a certain resolution.
I'm not sure where to look for source of problem - plugin or decoder...
Similar issue occurs with VP6 in FLV in a specific resolution (increased by a few pixels to multiple of 16?).
QUOTE (AEN007 @ Jan 21 2012, 05:01 PM)
MPEG-4 AVC (H.264)
AEN007
Posted: Jan 25 2012, 02:33 PM
25January2012
Greetings.
What would I need to do to DSC these flv files with 480x360/4:3 dimensions?
aviDemux does not stretch the dimensions of these flv files;
but when I copy the file to avi (with no audio) in aviDemux,
the output file video is all black.
MI says the audio of these files is 129 @ 44.1kHz.
DPMI specifies no bitrate @ 44.1kHz.
ViDub says the audio of these files is 128 @ 44.1kHz.
SMPlayer says the audio of these files is 131 @ 44.1kHz.
Placio74
Posted: Jan 26 2012, 07:30 AM
VideoAudio
QUOTE (AEN007 @ Jan 25 2012, 04:33 PM)
Because it is not designed for this (not adequately prepared AVC video to write in AVI).
Just save to proper container (MP4 or MKV).
Of course to change container You can use FLV Extract and MKVtoolnix (or My MP4Box GUI).
...MI says the audio of these files is 129 @ 44.1kHz.
Seems to it has a variable bitrate.
MedfiaInfo library is updated?
AEN007
Posted: Jan 26 2012, 03:49 PM
26January2012
QUOTE (Placio74 @ Jan 26 2012, 07:30 AM)
MI usually specifies if the audio is VBR but does not with these files.
ViDub gives no "VBR detected" notification ...
I opened one of these files into aviDemux and copied to mp4 (with no audio);
then opened into ViDub (without using the DSI driver); and then did DSC to avi ...
I hope this ViDub dimension stretch problem will "go away" one day ...
Placio74
Posted: Jan 26 2012, 09:00 PM
VideoAudio
If this audio is not VBR, then it may be result of a bit inaccurate reading of related to bitrate properties (file size, duration, ...)...
11 replies since Jan 27 2009, 12:16 PM Track this topic | Email this topic | Print this topic
