Show Status Window And Running A Script, Why is the Status Window not displayed
achibus
Posted: Dec 19 2007, 07:46 PM
I check the "Show Status Window" and the start a script. But then the VirtualDub starts without showing the status window and the menu entry is unchecked!
Is there a way to force VirtualDub to show the status window also while running a script without explicitly setting it via the view menu after I started the script?
Thank you very much
achibus
Posted: Dec 20 2007, 08:56 AM
Nope, sorry, not at the moment. The script commands that initiate save operations automatically disable the status window.
What are you trying to do, exactly?
achibus
Posted: Dec 20 2007, 02:13 PM
I'm developing a little application, that
1) creates a virtualdub script
2) opens a new process and calls virtualdub to run that script.
I would like to run virutaldub as a minimized window, but be able to configure virtualdub from outside to show the status window. This could be a registry setting or a command in the script.
Thank's for the clear answer in the replay and the interest in my suggestion.
achibus
jfarley
Posted: Feb 27 2012, 03:01 PM
I'm also trying to do this. Are there any new developments since 2007?
3 replies since Dec 19 2007, 07:46 PM Track this topic | Email this topic | Print this topic
