Tuner Settings Not Working
volki
Posted: Jul 20 2007, 12:30 PM
Hello,
First let me thank you for this excellent program. This is helping me too much. And almost flawless. Please keep this project up. With my best regards.
I am using 1.6.0 recent. My source settings are "Antenna, Channel 34" for capture. But when i run VirtualDub and switch to capture, my settings has been gone.
I checked my registry before running virtualdub.exe. "TunerFreq" is the same as my latest setting but it is/can not use it for some reason. When i enter "source..." the channel:4 , Entry: Cable everytime. But they must 34, Antenna.
System : XP sp1
cpu : p3 450 mhz
VDub : Saved my "capture Preferences"
NOTE: I use one of "K-Lite Codec Pack" because of watching many different internet video sources. The problem is, my computer is a bit slow and when i want to capture from TV, virtualdub is loading ALL of the codecs first. But i always capture only one of the codec(which i already saved with "Capture Preferences") in codecs list. The others only for mplayer, for watching. I wish i may check the codecs which i prefer to load next time, till i need different(maybe).
foxidrive
Posted: Jul 20 2007, 12:39 PM
I would think that while Virtualdub does list all the codecs it only loads the codec it is using.
As for your antenna setting have you tried saving the processing settings (from the file menu) and loading them again before capturing? See if that works - and if it does you could do it automatically from a shortcut.
i4004
Posted: Jul 20 2007, 01:54 PM
1.6.xx doesn't save tuner settings..
but 1.7.x does....
my signature:
volki
Posted: Aug 1 2007, 08:34 PM
First, thank you foxidrive and i4004. Sorry for this space but i was checking e-mail to notify me replies. And just want to check out.
for me, this is not completely exact. Ok, 7 codecs loading. For my system, waiting 1.5 min until ready to capture.
foxidrive
Posted: Aug 2 2007, 01:07 PM
QUOTE (volki @ Aug 2 2007, 06:34 AM)
blink.gif Mine is ready to go as soon as I launch my capture batch file.
volki
Posted: Aug 2 2007, 11:52 PM
capture batch file
what is it?
foxidrive
Posted: Aug 3 2007, 04:56 AM
There are two lines - For Win9x/ME remove the ""
@echo off
start "" /max "c:\Program Files\V_Dub\VirtualDub.exe" /capture /capfileinc c:\storage\capture.avi
6 replies since Jul 20 2007, 12:30 PM Track this topic | Email this topic | Print this topic
