| Sakaki-san |
Posted: Sep 23 2003, 11:30 PM |
I hope anyone can help me here my Settings:
Filters: Deinterlace, Smart smoother HQ, Warp Sharp, VobSub, Resize XviD: Latest from Nic (16/07/03) VDub Mod Ver.: 1.5.4.1
XviD Settings:
- Global Motion Search: Ultra High Quantization type: MPEG VHQ: Mode Decision Max. I-Frame Interval: 300 Min. I-Frame Interval: 1 Max. B-Frames: 2 B-Frame Quantizer ratio: 150 B-Frame Quantizer Offset: 100 DX50 B-VOP...: Checked Chroma Motion: Checked
- Alt. Curve Alternative curve System: off Max. Bitrate: 10000 Max. overflow improvement: 60 Max. overflow degradation: 60
- Debug
Force optimizations: MMX: Checked Integer SSE: Checked SSE: Checked All Other: unchecked Frame Drop Ratio: 0
System:
Intel P4 1,8GHz (Willamette Core), ABIT TH7-II, 2*256MB PC-800, WinXP Pro (SP1)
Crash Log:
VirtualDub crash report -- build 2066 (release) --------------------------------------
Disassembly: 07ea2060: e90fddf38d jmp 95ddfd74 07ea2065: 3456 xor al, 56 07ea2067: 0f71d501 psrlw mm5, 01 07ea206b: 0f71d601 psrlw mm6, 01 07ea206f: 0f67ee packuswb mm5, mm6 07ea2072: 0f6fc8 movq mm1, mm0 07ea2075: 0f6fda movq mm3, mm2 07ea2078: 0f60c7 punpcklbw mm0, mm7 07ea207b: 0f60d7 punpcklbw mm2, mm7 07ea207e: 0f68cf punpckhbw mm1, mm7 07ea2081: 0f68df punpckhbw mm3, mm7 07ea2084: 0f6ff4 movq mm6, mm4 07ea2087: 0f60e7 punpcklbw mm4, mm7 07ea208a: 0f68f7 punpckhbw mm6, mm7 07ea208d: 0fe9c4 psubsw mm0, mm4 07ea2090: 0fe9ce psubsw mm1, mm6 07ea2093: 0f6ff5 movq mm6, mm5 07ea2096: 0f60ef punpcklbw mm5, mm7 07ea2099: 0f68f7 punpckhbw mm6, mm7 07ea209c: 0fe9d5 psubsw mm2, mm5 07ea209f: 8d0450 lea eax, [eax+edx*2] 07ea20a2: 0fe9de psubsw mm3, mm6 07ea20a5: 8d1c53 lea ebx, [ebx+edx*2] 07ea20a8: 0f7f4160 movq [ecx+60], mm0 07ea20ac: 0f7f4968 movq [ecx+68], mm1 07ea20b0: 0f7f5170 movq [ecx+70], mm2 07ea20b4: 0f7f5978 movq [ecx+78], mm3 07ea20b8: 5e pop esi 07ea20b9: 5b pop ebx 07ea20ba: c3 ret 07ea20bb: 90 nop 07ea20bc: 90 nop 07ea20bd: 90 nop 07ea20be: 90 nop 07ea20bf: 90 nop 07ea20c0: 8b4c2404 mov ecx, [esp+04] 07ea20c4: 8b442408 mov eax, [esp+08] 07ea20c8: 53 push ebx 07ea20c9: 8b5c2410 mov ebx, [esp+10] 07ea20cd: 56 push esi 07ea20ce: 8b742418 mov esi, [esp+18] 07ea20d2: 8b54241c mov edx, [esp+1c] 07ea20d6: 0fefff pxor mm7, mm7 07ea20d9: 0f6f00 movq mm0, [eax] 07ea20dc: 0f6f1410 movq mm2, [eax+edx] 07ea20e0: 0f6fc8 movq mm1, mm0 07ea20e3: 0f6fda movq mm3, mm2 07ea20e6: 0f60c7 punpcklbw mm0, mm7 07ea20e9: 0f60d7 punpcklbw mm2, mm7 07ea20ec: 0f6f23 movq mm4, [ebx] 07ea20ef: 0fe026 pavgb mm4, [esi] <-- FAULT 07ea20f2: 0f68cf punpckhbw mm1, mm7 07ea20f5: 0f68df punpckhbw mm3, mm7 07ea20f8: 0f6f2c13 movq mm5, [ebx+edx] 07ea20fc: 0fe02c16 pavgb mm5, [esi+edx] 07ea2100: 0f6ff4 movq mm6, mm4 07ea2103: 0f60e7 punpcklbw mm4, mm7 07ea2106: 0f68f7 punpckhbw mm6, mm7 07ea2109: 0fe9c4 psubsw mm0, mm4 07ea210c: 0fe9ce psubsw mm1, mm6 07ea210f: 8d3456 lea esi, [esi+edx*2] 07ea2112: 0f6ff5 movq mm6, mm5 07ea2115: 0f60ef punpcklbw mm5, mm7 07ea2118: 0f68f7 punpckhbw mm6, mm7 07ea211b: 0fe9d5 psubsw mm2, mm5 07ea211e: 8d0450 lea eax, [eax+edx*2] 07ea2121: 0fe9de psubsw mm3, mm6 07ea2124: 8d1c53 lea ebx, [ebx+edx*2] 07ea2127: 0f7f01 movq [ecx], mm0 07ea212a: 0f7f4908 movq [ecx+08], mm1 07ea212e: 0f7f5110 movq [ecx+10], mm2 07ea2132: 0f7f5918 movq [ecx+18], mm3 07ea2136: 0f6f00 movq mm0, [eax] 07ea2139: 0f6f1410 movq mm2, [eax+edx] 07ea213d: 0f6fc8 movq mm1, mm0 07ea2140: 0f6fda movq mm3, mm2 07ea2143: 0f60c7 punpcklbw mm0, mm7 07ea2146: 0f60d7 punpcklbw mm2, mm7 07ea2149: 0f6f23 movq mm4, [ebx] 07ea214c: 0fe026 pavgb mm4, [esi] 07ea214f: 0f68cf punpckhbw mm1, mm7 07ea2152: 0f68df punpckhbw mm3, mm7 07ea2155: 0f6f2c13 movq mm5, [ebx+edx] 07ea2159: 0fe02c16 pavgb mm5, [esi+edx] 07ea215d: 0f6ff4 movq mm6, mm4
EAX = 0a5ba2e0 EBX = 09f811a0 ECX = 0b4ff2c0 EDX = 00000300 EBP = 00000000 DS:ESI = 0023:462ef83e ES:EDI = 0023:09f811a0 SS:ESP = 0023:0b4fedc8 CS:EIP = 001b:07ea20ef FS = 003b GS = 0000 EFLAGS = 00010202 FPUCW = ffff037f FPUTW = ffffaaaa
MM0 = 00bf00c300b70093 MM1 = 8f818cbebfc3b793 MM2 = 00c200c600ba0096 MM3 = 908088b8c2c6ba96 MM4 = 90818cbdbec3b792 MM5 = 0000000000000000 MM6 = 0002000200020002 MM7 = 0000000000000000
Crash context: An out-of-bounds memory access (access violation) occurred in module 'xvid'...
...while compressing frame 10112 from 0875ac80 to 09a30020 (VideoSequenceCompressor.cpp:375)...
...while running thread "Processing" (thread.cpp:105).
Thread traces:
Thread 00000328 (Main thread) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(125) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(123) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(125) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(123) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(125) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(123) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(125) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(123) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(125) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(408) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(408) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(408) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(408) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(408) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(408) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(424) Thread 000006e4 (FastWriteStream) Thread 00000780 (Processing) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1607) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSource.cpp(1640) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\Dub.cpp(4231) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(512) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(525) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(512) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(525) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(512) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(525) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(512) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(525) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(512) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(525) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(512) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\FilterSystem.cpp(525) C:\Dvpt\VDub_1.5.x\VirtualDubMod15\VirtualDub\source\VideoSequenceCompressor.cpp(373) Thread 00000554 (Dub-I/O)
Thread call stack:07ea20ef: xvid!xvid_init [07e60000+b028+370c7] 07eb1cbe: xvid!xvid_init [07e60000+b028+46c96] 07e7d24b: xvid!xvid_init [07e60000+b028+12223] 77fa1700: ntdll!RtlConvertUlongToLargeInteger [77f40000+616c0+40] 00630069: VirtualDubMod!00230069 77f839de: ntdll!RtlNtStatusToDosError [77f40000+439a6+38] 77f839e3: ntdll!RtlNtStatusToDosError [77f40000+439a6+3d] 07e791dd: xvid!xvid_init [07e60000+b028+e1b5] 07e65aa6: xvid!00005aa6 07e6a8a7: xvid!xvid_encore [07e60000+a864+43] 07e655aa: xvid!000055aa 07e6a54c: xvid!DriverProc [07e60000+a2cc+280] 77e5da3a: kernel32!CompareStringW [77e40000+1d995+a5] 77f844a8: ntdll!RtlRemoteCall [77f40000+442ea+1be] 77f844a8: ntdll!RtlRemoteCall [77f40000+442ea+1be] 77f47d70: ntdll!RtlAllocateHeap [77f40000+7bae+1c2] 77f48a3a: ntdll!RtlAllocateHeap [77f40000+7bae+e8c] 77e55dbd: kernel32!CompareStringA [77e40000+15cf8+c5] 77f4bfb4: ntdll!NtReadFile [77f40000+bfa8+c] 77e5abbd: kernel32!ReadFile [77e40000+1ab4e+6f] 77e5abdc: kernel32!ReadFile [77e40000+1ab4e+8e] 057f5c28: DVD2AVI!00005c28 77f844cb: ntdll!RtlRemoteCall [77f40000+442ea+1e1] 77f48bcd: ntdll!RtlFreeHeap [77f40000+8a3e+18f] 77f49037: ntdll!RtlFreeHeap [77f40000+8a3e+5f9] 057f64d6: DVD2AVI!000064d6 77f49037: ntdll!RtlFreeHeap [77f40000+8a3e+5f9] 07db6460: SmoothHiQ!VirtualdubFilterModuleDeinit [07db0000+4520+1f40] 07db52e1: SmoothHiQ!VirtualdubFilterModuleDeinit [07db0000+4520+dc1] 07db44c5: SmoothHiQ!000044c5 00442054: resize_table_row() 0044251f: resize_table_col() 00443ee7: Resampler::Process() 0043b1fa: resize_run() 73b4181d: MSVFW32!ICSendMessage [73b40000+17f4+29] 73b44789: MSVFW32!ICCompress [73b40000+4728+61] 0049e9f6: VideoSequenceCompressor::packFrame() 004778c0: Dubber::WriteVideoFrame() 77e5a652: kernel32!WaitForSingleObjectEx [77e40000+1a5a2+b0] 77e5ac21: kernel32!WaitForSingleObject [77e40000+1ac12+f] 00517692: VDSignalBase::wait() 0046b377: AVIPipe::getReadBuffer() 00478495: Dubber::ThreadRun() 77e53887: kernel32!RaiseException [77e40000+13837+50] 77f4b884: ntdll!NtDuplicateObject [77f40000+b878+c] 77e5f01b: kernel32!DuplicateHandle [77e40000+1efb6+65] 77e5f02b: kernel32!DuplicateHandle [77e40000+1efb6+75] 77e5f02b: kernel32!DuplicateHandle [77e40000+1efb6+75] 005175b9: VDThread::StaticThreadStart() 0054f4ca: _threadstartex@4() 77e5d33b: kernel32!RegisterWaitForInputIdle [77e40000+1d2f8+43]
-- End of report |
| Posted: Sep 24 2003, 01:14 AM |
Looks like a crash in Xvid's B-frame motion prediction search. |
| Posted: Sep 24 2003, 04:54 AM |
Suggestion: When you resize, make the width and height of your video multiples of 16 (if they are not).
| ChristianHJW |
| Posted: Sep 24 2003, 06:23 AM |
| QUOTE (phaeron @ Sep 24 2003, 03:14 AM) | | Looks like a crash in Xvid's B-frame motion prediction search. | I send sysKin here, the developer of XviD's ME ...
| Sakaki-san |
| Posted: Sep 24 2003, 12:30 PM |
hmmm, any idea what i can do against this Prob (other Settings)? I still must encode 6*20 mins and dont want to use DivX3/5 XD.
ChristianHJW: thx ^^ |
