Vdbmod 1.54 Bug?, about dts
meilin
Posted: Sep 8 2003, 11:07 AM
I do not have a "standard" dts file,i just create a dts-wav with surcode cd pro dts,then use wav2dts to convert it to a dts file,but vdbmod 1.54 can not parser this file,however,i can use mkvmerge.exe to mux this file with a silence avi,and this file can be play.if i use avi-mux i will get some sync problem.
so,when i want a avi-dts,i first create a mkv file,then convert it to a avi file.but i want virtualdubmod can create the avi file directly.
thx
Suiryc
Posted: Sep 8 2003, 02:32 PM
Developer of VirtualdubMod
Group: VirtualdubMod Team
Is there a specific error or only "This doesn't appear to be a valid DTS file" ?
meilin
Posted: Sep 9 2003, 10:02 AM
yes it is!
is that mean you have found the problem?
thx
meilin
Posted: Sep 9 2003, 10:08 AM
sorry,i mean the err msg is "This doesn't appear to be a valid DTS file"
Suiryc
Posted: Sep 9 2003, 08:21 PM
Could you cut the first Mb of your file and send it to me ? (suiryc AT yahoo DOT com)
meilin
Posted: Sep 10 2003, 09:43 AM
ok,i have sended the file to you:)
please check it, the filename is:test.dts smile.gif
Suiryc
Posted: Sep 10 2003, 01:14 PM
Thanks.
There was indeed a problem in the code ... the DTS parser was broken (resulting in problems - as for you - when opening the DTS file, or problems when muxing the DTS file - because of wrong values).
The version here (the 'Release' means it's a release - as opposed to debug - build).
meilin
Posted: Sep 11 2003, 09:29 AM
thx Suiryc,It works now:)
and,happy mid-autumn festival
7 replies since Sep 8 2003, 11:07 AM Track this topic | Email this topic | Print this topic
