| nithro |
| Posted: Aug 14 2003, 11:20 PM |
Hello everyone. I was using Gknot 0.28.2 a long time now. One day I install a new Xvid codec and all the problems beguns. First of all I don't think this problems are caused by the installation of a new Xvid codec, all I know is all the times I want to use Virtualdubmod 1.5.1.1a since the installation this error appears "Couldn't locate decompressor for format YV12". I don't know what cause this, but Ican't use gordianknot anymore since this happened yesterday. I see in other forums deleting some entries in the registry will fix it, i try everything but nothing fix this I used Divx 5.0.5. Please if someone knoe how to solve this, please let me know.
Thanks! Thanks!-
Nithro.
¿Why nobody help me? , it is because I am a little newbie in the forum?. |
| minion |
| Posted: Oct 12 2003, 01:31 AM |
I have had this Problem with Some AVIsynth Scripts useing CCE to encode and I solved it by Installing the FFDShow Decoder and Configure it to decode all Mpeg4 formats and to decode all Raw Formats includeing YV12...This solved my problem it might help you...Cheers |
| ChristianHJW |
| Posted: Oct 12 2003, 11:13 AM |
Hmmm .... installing DivX5 should solve this ? .... no idea why it doesnt work for you, sorry ..... you made a search here already ?
